Bravo raw pump, Old style to new?
PARADOX
Founding Member
Can an old style, 2-3 peace raw water pump assembly be changed to the new style one peace unit?
1994 Bravo with 454 Mag. The impeller housing is the old style and I want to change it over to the one peace unit. It will fit, so can it be just changed? or there is something I need to be aware of.?
Thx
P
Yes, that is the standard upgrade, IIRC some of the 3 piece parts are no longer available and you simply bolt on the one piece kit, it even comes with bolts. No fuss, no muss.
Be aware that the one piece housings are notorious for cracking and then sucking air and overheating engines. The regular bodies used to be available but harder to assemble on the engine. I usually pull the whole pump out and do it on the bench. I havent bought any parts for mine in a year, I hope they didnt do away with them all together.
What Rogue said is true, you have to be careful with the one piece body, best to swap on the bench if possible.
We can still get the old style kits from Merc, and looking at their inventory I would say they are not going away anytime soon..
Yeah.. :) but that first few mile is a bummer. I can see the bottom for half an hour before I get to some open seas.
And thats at 60 MPH!
I changed 2 of them today for sombody on LBK and there was no sand damage at all, only old impellers.
What I saw on several boats was that the wear strip that bisects the ports wears out prematurely and will eventually part allowing the sharp ends to destroy the impeller
Mark - stay out of the sand ... LOL!!
I shy away from the "aftermarket" one peice kits - but have plenty of luck with the factory Merc ones.
A lot of my "older" clients request the button be installed on the impeller shaft - not sure if this really helps - but many of the older guys swear by them. I can't tell the difference - we change most of them yearly whether they need them or not.... cheap insurance.
I try,easier said than done as you well know.
Unfortunately I have the room and the tools, so one way or another I get to work on 3 or 4 boats. I have noticed that the ones that have the old style pumps seem to keep their impeller's in much better shape, but since all of us beach our boats regularly we may see a lot more sand than most.
