HaxbySpeed
The length of the tubing and bends has almost no effect on boost or how long it takes to build. Unless you go crazy..
As an example, a rear mounted STS turbo system where the turbos are mounted by the rear axle has absolutely no noticeable difference in driveability then a conventional set up. The SC moves such a huge volume of air it takes very little time to pressurize the system. I think you are safe to route it whichever way works best for you just keep your bends smooth and aviod any restrictions..
