Anyone know upper and lower gear ratiosfor No.6's
Lubejobs42
I need to know what the upper and lower gear ratios combinations are for different Number 6 drive ratios.
Thank you!!
1:24
Upper gear?
Lower gear?
1:29
Upper gear?
Lower gear?
1:35
Upper gear?
Lower gear?
Thank you!!
1:24
Upper gear?
Lower gear?
1:29
Upper gear?
Lower gear?
1:35
Upper gear?
Lower gear?
It depends ,,there are diffrent varities.
U can have 1:1 lowers or 1:125 lowers and then diffrent uppers to get there,
with 1:1 lowers it would be the overall in the upper ,,which is not very good because if u split the ratio in both u will basicley split the load in both and they last longer and take more.
U would need to count the teeth to find out what u have .
These are just stock Merc drives. I need to know what they put in them.
To change a 1:35 to a 1:29 you need to change both upper and lowers
but to
To change a 1:24 to a 1:29 you need to change the lower.
Many cats have a 1:29 which do not come stock from Mercury, they are made to be a 1:29.
but to
Gino,,let me check tomorrow and i get back with u.
