Thread: Joe Gibbs Oil
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 45
    Joe Gibbs Oil
    Question
    OK guys, what does anyone know about this oil. It has a lot of hard core race teams (not marine that I know of) using it.
    They claim to have huge ZDDP content and formulate it (ZDDP) based on your operating temps among other things such as RPM, HP big or small block and type of racing. These are not formulated for street use.
    Any opinions out there for Marine use?
    http://www.joegibbsracingoil.com/
    XP 6 is wnat I am looking at due to temperatures formulated for.
    Very expensive BTW
    Cause somebody has to!
    why whats the temp rating gotta do with your boat. most of the offshore boats or hi-perf boats seem to have trouble making oil and water temp?
    I run oil thermostats and closed cooling so I never have a low temp problem. I hang @ about 220 but can spike up to 270-280 on long WOT runs. I am making some rigging changes now to improve my Teague Oil Cooler's efficiency now but am still interested in using the best oil for my application.
    I have been using V-Twin and am planning to try Amsoil. I was tipped off to the Gibbs products by my cylinder head specialist.
    the full synthetics are just too expense. i've run amsoil and torco in a hi compression 355 race motor, both are good and i had no problems. i also used synthetics in our offshore race boat. but when you run a 5 gallon dry sump tank it gets costly. the engine builder i use said that i was wasting my money and he recommends brad penn 20-50 race oil. its less than half of the others. plus i would rather change the oil more often so as to keep an eye on it. using the brad penn i can change the oil twice and still spend less than the asmoil for one change.
    plus 280 degrees is ok, over 300 is when problems start!
    nothing against gibbs, but i doubt he produces the oil, he's just repackaging some one elses stuff with his name on it, so why pay for bush to drive a toyota and act like an a-hole?
    plus the only way to know if there's a benefit is to send your oil out and do an oil analyisis
    Quote Originally Posted by skaterdave View Post
    I agree, I heard it is made by "Lubrizol" though I don't know of them.
    Damn good point
    And what would I be checking for? contaminants? Breakdown?
    I am changing oil every 20 hours (6 gallons per change) and filters every 10. I cut my filters open and scan with a magnet. It is expensive but my engines weren't cheap.
    "the full synthetics are too expensive".............hmmmmmmm you've probably got a boat that cost $150000 or more, plus truck, maybe some toys, and you're *****ing about a few dollars more, for a far superior product to petroleums? Guys like you make me laugh. As far as I'm concerned, I'm going to put the best product in my boat that I can find, cost doesn't matter. You do make one good point, use oil analysis, that is the only way to know if your oil is good or not. My AMSOIL 20w-50 Racing Oil, with 53 hours from last year, was still good to use, cleaner and stronger than Merc 25w-40 out of the bottle. I still change once a season, however.
    Ding ding, Winner winner chicken dinner. You are correct. Lubrizol makes many of the additives that go into varioius off the shelf oils. Althought they are one of the largest additive company out there, you will not find there name on any product. I beleive there biggest competitor is Mobil, which has an additive division.
    FYI. They have been working with Joe Gibbs since roughly 1995.....
    Jr.
    OK, We have worked through a few issues here
    So anybody know if the Gibbs brand (Lubrizol) stuff lives up to their claims? :bigear:
    It is nearly 50% more $ than the two brands I would trust (mobil and amsoil).
    2112.,
    Honestly, I know the product & the company but, I will be honest, I dont know how good it would be in a offshore application. I wish I would have found out. We all know that ZDDP is important. But, the base oill is just important.............. Sweet crude, that makes the best base. It comes from the countries that we have guns pointing at........ Anyways, I have some good pics of your boat at the factory in Opa Locka... I should scan them in and post. It was the coolest cig I saw there!!!
    my engine guy recommended that i run joe gibbs oil in my engines.
    Quote Originally Posted by 07DominatorSS View Post
    synthetics are better for various reasons. number one would be that they don't break down as quick as conventional or partial syn's so you can run them longer and there fore the added expense might be worth it.
    in high temp situtation such as turbos or extreme high rpm race motors they agian protect longer and don't break down so quickly. but agian if your changing oil every other race than your not getting the benefits. and certain things play havoc on syn's. such as methanol which breaks down synthetics much quicker than a conventational oil. also in a high perf motor you'll get blow-by into the oil no matter what so sometimes its better to change the oil more often and you'd be wasting $$$$.
    look at the zinc and phosphate #'s to get a idea the tech difference and i think that most all the main race oils would work.so then it comes down to preference and cost.
    also donimatorSS you should also look up water saturation. i just had this discussion with engine builder about how often to change oil if the motor has been siting for awhile. and just like gas oils can absorb water. so food for thought, especially if you leave your boat in the water
    I would love to see some documentation stating that petroluems won't break down as fast as a synthetic, with the presence of methanol. I've personally seen info from Shidaiwa, one of the largest producers of 2 cycle equipment in the world, stating to only use a high quality synthetic 2 cycle mix, due to ethanol and methanol presence in gasoline nowadays. Synthetics being able to counteract the presence of the alcohol, by adhering to the cylinder walls better, helping to prevent the alcohol from stripping the film of oil on the cylinder walls.
    Secondly, who is your engine builder, I would change from him tomorrow. He sounds like a complete idiot! Oil and water don't mix!!! (2nd grade chemistry).
    Secondly, who is your engine builder, I would change from him tomorrow. He sounds like a complete idiot! Oil and water don't mix!!! (2nd grade chemistry).[/QUOTE]
    i guess you've never changed a drive with a bad seal??
    if your boat sits in a place with a lot of condensation, i sure you know what that is, the condensation will build inside your engine just like when theres condensation in your house or car. especially if the boat is sitting just inches away from the water. and unless your engine makes good oil temp (190-240) and water temp (150-180) you will never burn off the moisture. and last i checked water doesn't lubricate too good. now this probably doesn't effect the guy that changes his oil routinely but if your going all season, well....
    but hey, your probably that type of guy that brags about using $20 a quart oil in a 600 cubic in motor that makes 500 hp. oh yeh, but you only have to change it once a year?
    you do understand the difference with 2 vs 4 stroke? even better your taking your hi-performance tips form a weed wacker manufacture?
    I use the Gibbs Break in oil in almost every motor I build, and I've used their other synthetics in lots of applications with excellent results but I've never tried it in a boat. I just don't know if it's right for that application either. It's great quality oil but does it have what it takes to live for three months in a damp crank case that sees extreme heating and cooling cycles mixed with some salt water fuel/ethenol etc?
    Quote Originally Posted by HaxbySpeed View Post
    appearently the lawn mower people have done testing and have all the answers?
    I use Gibbs BR break in oil for break in on all flat tappet engines. Gibbs offers non synthetic products as well... I've run the XP4 (which is the same oil as the BR in a different bottle) non synthetic in many marine applications without any issues.
    Very expensive BTW
    We went to a seminar this winter for Joe Gibbs Oil and Lake Speed junior spoke for a few hours. Very impressed,.......Joe Gibb's worked with the oil company for a few years to get the product to there specs. So when you buy Joe Gibbs oile you are getting the same oil as the race cars.
    When you buy Mobil 1 it is not the same formula as the race cars.
    We are switching to it and will be using there break in oil also.
    They spent millions testing oils, break in thery's old school new school.
    I will say they did there home work and I left more educated than I ever thought I could be on oil.
    Thanks
    Jon
    you do understand the difference with 2 vs 4 stroke? even better your taking your hi-performance tips form a weed wacker manufacture?[/QUOTE]
    You're finally right on something, water doesn't lubricate very well. But when it actually comes to oil, you don't have a f**cking clue what you're talking about. I test my oil, to make sure its good. When that test is taken, it'll tell me if there is too much water in the oil, oh, thats right, there wasn't any after 53 hours, a full season for me. I don't use $20/qt oil, I use AMSOIL 20w-50 Racing oil, in my twin 496ho's. I'm sure you know the reason too, why all commercial airlines, every piece of military equipment, secret service, NASCAR use synthetics right? Oh yeah you obviously don't, its because they are far superior in film strength, resist breakdown, handle temperature variation much better, and can handle by-products of combustion much better. When you mention a drive with a bad seal, well, its bad seal, and yeah, there will be too much water in there. But for you to tell me that oil can absorb water, thats some funny sh*t!
    I run Joe Gibbs XP5 Semi Synthetic in my 540 Tunnel Ram motor as per my engine builder's advice.
    Dont have the knowledge to comment with some on here but thought I would put that out there.
    I pay roughly 14 bucks a liter (CDN $).
    I don't use $20/qt oil, I use AMSOIL 20w-50 Racing oil, in my twin 496ho's. I'm sure you know the reason too, why all commercial airlines, every piece of military equipment, secret service, NASCAR use synthetics right? Oh yeah you obviously don't, its because they are far superior in film strength, resist breakdown, handle temperature variation much better, and can handle by-products of combustion much better. When you mention a drive with a bad seal, well, its bad seal, and yeah, there will be too much water in there. But for you to tell me that oil can absorb water, thats some funny sh*t![/QUOTE]
    thats great stuff there!!!!! your comparing your 496's to nascar engines?
    well i guess you buy Amsoil racing 2 stroke oil for your weedwacker too? hea have at Amsoil needs the money for teagues sponsorship.
