Results 1 to 20 of 28
    Tach problem on my Avalanche.
    Founding Member Buoy's Avatar
    Apache Jct. AZ
    I have a 2004 Chevy Avalanche 2500. 4x4, 8.1 ltr.
    Yesterday had all tires replaced, and alignment done.
    Today, (first I've really driven the truck since having the work done) on my way to work, running down freeway ~65-70mph, I glance down at the gauges, and my Tach is reading 6000 rpm. Now, I know I would have noticed this just by the sound of the motor, but it still freaked me out. Stopped at a stop light, motor is idling just fine, everything is normal, but Tach is reading 4000 at idle.
    Truck shifts as normal when accelerating. Turn truck off, and Tach remains reading at 4000.
    All other gauges are right where they should be. (oil temp, trans temp, etc...)
    So for you mechanical gurus, what is causing this, and how do I fix it?
    Seems like this should be something fairly simple.
    I certainly don't think the tires and alignment would have anything to do with this, but I wanted to mention it so as not to leave any info out.
    I wonder if they pinched something (wires) when they put it on the lift.
    there is a bulletin about this, your not the first...
    you need a compatible scan tool to verify the correct signal from the powertrain control module (PCM) to the instrument control module (ICM). Odds are your tach is pooched but scan data of the rpm signal would be the best and quickest way to prove it. A tech2 scan tool can be used in bi directional mode to operates the gauges and verify that end of it.
    The tach does not receive a signal from the coil like the OLD days. Its info is purely digital on the network and requires the ICM to decode it and move the tach needle accordingly.
    Registered inbetween's Avatar
    Mentor, Ohio
    won't be the last either
    Lake Nasty
    My truck doesn't have a tach.
    God knows what could be happening in there.
    My present to you, hope you fall in the year/mileage breaks:
    Document ID# 2037454
    Subject: Special Coverage Adjustment-Instrument Panel Cluster Gauge Needle Functions #07187A - (11/08/2007)
    Models: 2003-2004 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT
    2003-2004 CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE
    2003-2004 GMC SIERRA, YUKON, YUKON XL
    THE SERVICE PROCEDURE IN THIS BULLETIN HAS BEEN REVISED. IN A SMALL NUMBER OF VEHICLES, THE GAUGE SWEEP TEST MAY NOT ALWAYS CONFIRM THE CONDITION. PLEASE REVIEW THE SERVICE PROCEDURE IMMEDIATELY.
    DUE TO PART AVAILABILITY, THIS SPECIAL COVERAGE IS BEING ADMINISTERED IN PHASES. YOU WILL BE NOTIFIED AS EACH ADDITIONAL PHASE IS RELEASED.
    CUSTOMERS ARE BEING INSTRUCTED TO CONTACT THE DEALERSHIP TO ARRANGE AN APPOINTMENT IF THEY BELIEVE THEIR VEHICLE HAS THIS CONDITION. THE CUSTOMER IS BEING ASKED TO PROVIDE THE VIN SO THE IPC CAN BE ORDERED IN ADVANCE OF THE SCHEDULED APPOINTMENT. THIS WILL ELIMINATE THE NEED TO KEEP THE VEHICLE OVERNIGHT. DEALERS ARE TO OBTAIN THE VEHICLE MILEAGE WHEN SCHEDULING A SERVICE APPOINTMENT. THE VEHICLE MILEAGE WILL BE REQUIRED WHEN PLACING AN ORDER FOR THE IPC.
    Condition
    Some customers of 2003-2004 model year Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles have reported that one or more of the instrument panel (IP) cluster gauges stick, flutter, or become inoperative. This may cause inaccurate readings, including the speedometer and fuel gauge.
    This special coverage covers the condition described above for a period of 7 years or 70,000 miles (110,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
    Dealers are to replace the instrument panel cluster after the condition has been verified. The repairs will be made at no charge to the customer.
    For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after September 28, 2007 are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to September 28, 2007, must be submitted to the Service Contract provider.
    Vehicles Involved
    Involved are certain 2003-2004 model year Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles built within the following VIN breakpoints:
    You need to check with your dealer to see if yours qualifies.
    Apache Jct. AZ
    Thanks Ted!!
    Yep, sounds like mine fits all the criteria. 2004, and a little over 41K miles.
    I'll call the dealer this week.
    Thanks again!
    It's the stepper motors in the gauges that go bad in these years. It's actually a easy fix if the dealer doesn't want to help you. I replaced all mine in the tahoe earlier this year, not because they went bad but just as a precaution. Plus I added the trans temp. gauge. You can have the dash out in under five minutes and solder a new stepper motor in pretty easily.
    Mentor, Ohio
    Quote Originally Posted by 99fever27 View Post
    Post a link to the source for the motors. My out of warranty '04 Yukon could benefit from them.
    All over da place.
    I think my Brother in Law has gone through 3 dash units on his 2003 Avalanche 1500. Neither of our 2002 Avalanche 2500s had a problem.
    wwwActiveThunderBoats.com
    Apache Jct. AZ
    Yeah, I know what ya mean.
    As long as it's there, I want it fixed.
    Think about it, if you're tooling down the highway at 70, glance down and note the tach at 6K, there is a certain pucker factor that you are very soon going to have oil all over your windshield, and possibly a rod through the block.
    Lake Nasty
    No doubt, and once you are a boater.... you become a tach watcher. Oil pressure and temp too. It would have been a wtf?!? moment for sure. Like looking at your oil pressure and its 5. Or less.
    yes and problems will compile , and the next thing you know it is an
    avalanche
    I am officially out of material
    Apache Jct. AZ
    Yeah, I think that's why it got to me so bad...
    Boat related dementia or something...
    Yep, I find myself checking all gauges every few minutes, must be ingrained in me.
    When I saw 6K on the tach, I was looking to chop the throttles, and be ready to get back on it upon re-entry.
    And also thinking that the new tires I was out testing needed more pitch
    avalanche
    Say goodnight Bobcat.
    Quote Originally Posted by inbetween View Post
    http://cgi.ebay.com/ebaymotors/1-200...Q5fAccessories
    And a write up for installing a tranny temp. guage but it applies for replacing the motors too......
    http://z71tahoe-suburban.com/iboard/...=stepper+motor
    Apache Jct. AZ
    Spoke with the local dealer today, and had to drop by with the truck for some more # ID.
    Fully covered under warranty. Parts will be in tomorrow. I'll drop it off Friday and have the work done.
    Funny, as soon as I got off the phone with the dealer, I went out to take it in, and everything was working just fine. Whatever, they are replacing it anyway.
    Thanks again guys Ted, Buizilla, for saving me the search time, and money that I was about to dig into this.
    Registered wannabe's Avatar
    Sep 2009
    Troy, Mich
    Buoy: There is a Avalanche website http://www.chevyavalanchefanclub.com/cafcna/index.php
    Try there for answers- Instument cluster extended warranty.
    Glad dealer is taking care of it.
    wannabe
    Apache Jct. AZ
    Thanks!
    I've been on that site before, but the group here is so knowledgeable on so many different things I just posted the question here and figured someone would have an answer in no time - I was right
    Dealer fixed me up no question, no charge, and a good job washing it!
