Results 41 to 60 of 89
    Quote Originally Posted by WOTW2E View Post
    69.9
    30ol, tiny little 377 scorpions, 3 full sized MEN, 3/4 fuel, 26" labbed props, fully loaded with gear. Probably 72 maybe 73 setup for a speed run.
    WOTW2E stands for "waitin' on the warranty 2 expire" then whipples! I would like to see a solid 80.
    I know, I know the warranty has already expired...but so has my income, so the whipples wait.
    Screw the whipples you need CUBIC INCHES.
    God Bless America
    www.DocksPokerRun.com
    Quote Originally Posted by Dock Holiday View Post
    What I NEED is a more plentiful bank account!
    Charter Member TEAMBAJA's Avatar
    Ohio
    Save the money for Shasta and Gyros.
    Custom Boat Interiors & More............Check Out www.xt-innovations.com
    Quote Originally Posted by TEAMBAJA View Post
    Tonight?
    What is the top speed of your new Baja TB?
    burrie speedo 80mph putting trim tabs on 12 by 24in dail the carb and put a new prop boat is runnig good !!runnig a lot of boats on delaware river having a lot of fun
    Registered Trim'd Up's Avatar
    STL, on the ILL side
    I have had mine to 82.3 on gps so far. That's it for me until I get the external and tabs put on. I have alot more throttle left and another 1100 rpm's. Just an old 240 sport with a 3" raised X dimension, a few extra bulkheads, and no wood except the transom.
    Aug 2009
    Dwight, IL
    496 HO's and I've hit 71 GPS. I was hoping for a little more out of it, but I've never had less than a half a tank of fuel in it so that may make a bit of a difference. We will see at the end of the season.
    Registered insanity's Avatar
    Perrysburg, OH
    How did you get the 3"s? Shortie or just raise the drive? What is your X at now, 18"?
    I haven't cut mine yet. Trying to decide between 17" and 18"...It used to be at 15".
    I raised the outdrive. If I remember right I am I am at 18.25". It still hops right on plane even without tabs and a 30" prop. It is a different boat with the raised X, it rides much better. It will blow out occasionally on slow hard turns if I don't tuck the drive all of the way in but other than that it is all positve.
    Registered jeffswav's Avatar
    Oct 2009
    Millstadt IL
    I have a 236 Baja 489 stroker 500HP, 70 MPH GPS. Raising the x this year and hoping for 76.
    Just finished install of 540 horse 502s, boat ran 69 GPS with HP400s. Should run mid to high 70s. Have to wait until we are done with snow storms to find out. Think Spring!
    Just an old slug with 1000 hr 454 mags. 68.9 on gps
    Feb 2009
    Bettendorf, Iowa
    71-73 along side of a hustler with gps. not for sure but we seemed to be in tandem. Will get better numbers with my Marine Kinetics Engine!
    64 GPS. 496 Mag bone stock (except some new SS cup holders that I just put in as well as the new tune machine that screams!! ).
    fastest speed was 1st time out ( no gear or gas ) going down stream on a cold april morning
    hit 61.2 not bad for a 13500lb boat with bottom paint, normal summer TS is 57mph
    she has triple 454/330hp, nothing special...
    Oct 2009
    Millstadt IL
    Your boat with 500HP should run 70-71 MPH. I gained 5MPH with one of Bobs cams but I went from a Crane flat tappet cam. Since you already had a roller I would think a 3-4 MPH gain would be expected. Depends on what you told him you wanted to do. Get a GPS and see what she does!!!
    Registered Pat Bates's Avatar
    Jan 2010
    Louisville KY
    78 on gps. '92 270, built 502
    Very squirrely ride! Had some rpm's left, but not the 'nads.
    I no longer own the boat, but thought the vid was appropriate. 1990 210 ESS with a fairly nasty NA 496. Best top end I ever saw was 98.6. Put the boat back to stock before selling.
    http://www.youtube.com/watch?v=xL5cyKdWnF0
    Registered LSUbaja's Avatar
    Jan 2010
    baton rouge, louisiana
    2000 25' outlaw 502 MPI 66.3 and 487hr! on the ticker
    Jan 2010
    Louisville KY
    Quote Originally Posted by WETTE VETTE View Post
    Cool video!
    Here's a short clip of my old tub.....
    http://www.youtube.com/watch?v=TEbfp7iNzKQ
    I need hydraulic steering in a bad way.
