Need to know
White wire with black tracer connected to small post on slave solenoid - where does it go/what does it connect to?
What goes on the R post on the starter?
Brown wire with white tracer coming out of cannon plug - what does it go to?
Thanks ! At shop now posting on BB.
Thread: wiring harness questions
Results 1 to 7 of 7
07-12-2009 11:37 AMI saw a boat once!
07-12-2009 11:42 AM
The white wire from the slave solenoid goes to the trannie. It grounds the solenoid when in neutral.
The brown/white wire is most often the trim gauge lead. It is also used for oil temp.
The R on the starter is for ignitions with points. R stands for resistor. Points ignition operate at about 8 volts the R offers 12 volts at cranking to aid in starting.
07-12-2009 12:40 PM
Thanks! Appreciate the quick help.
I saw a boat once!
07-12-2009 02:46 PM
Jim, you da man... what a great resource on this board!
- 37,359
07-13-2009 08:23 AM
I'm just going to start titling all my threads "Hey Jim"
Thanks again, I left the shop happy last night after hearing engines crank over with the starter vs. going home pi$$ed with a wrech embedded in the side of the boat.
