How does the seal fit around the busing. It seems as if the bushing is the EXACT same size as the spring thing that is inside the seal?
Want to make sure I get this thing right....
Thanks,
Eric
Thread: Swivel Seal Question
Results 1 to 5 of 5
05-15-2009 07:46 PM
- Jan 2009
- 207
05-17-2009 05:59 PMThe seal has a larger O.D. it's not the same size as the bushing i'll look in the morning have 2 to rebuild. Whats a spring thing?
- Appleton, Wisconsin. Where we have 2 seasons... winter and road construction
- 4,120
05-17-2009 06:11 PMEric, I found online Merc Manuals you can view or download. Maybe you can find the info you need.
http://forums.iboats.com/showthread.php?t=251571•_•_•_▬_▬_▬_•_•_•
05-17-2009 08:32 PM
I went ahead and put it back in as best I could based on my research. When I was looking at the seal and the bushing it almost appeared that the seal was to fit around the bushing in some sort of way but there wasn't any mention of it in either manual I had. Both manuals just simply said to tap it in place and use a bushing Loc-Tite to keep it in place, so that was what I did.
The seal had a circular "spring" that ran around it on the inside of the seal??
