Results 1 to 5 of 5
    Installing -2" lowers
    Registered Floatindirty's Avatar
    Hammer City
    42' fountain stock 502 mpi's with 24p bravo ones will these still work?
    Red Bud,IL-LOTO
    No, sell them to me. Just kidding, I don't know.
    St. Petersburg
    On a Fountain you cannot say for sure but your RPM may increase. What is key is that you run at WOT at the appropriate RPM. If your RPM increases then you will need to step up to taller pitch props to bring the RPM back down to the target.
    Julie
    GO FAST or GO HOME!
    Registered ozarkdevil's Avatar
    Feb 2009
    E. Iowa
    Quote Originally Posted by ThrottleUp Props View Post
    Julie
    If you raise your prop shaft 2" and your prop slip #'s go up will a taller pitch prop help control your slip or is the only way to correct it is by adding a blade (3 blade to a 4 blade or a 4 blade to a 5 blade)?
    St. Petersburg
    Adding blades and diameter are two distinct possibilities to controling the slip.
    Good Job!
    Julie
    GO FAST or GO HOME!
