Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 47
    Props spinning in VS. out
    Tampa Area
    AS I understand it the bravo drives forward and reverse gears are the same. or interchangable. Meaning that it can go FT in "reverse" or in forward.
    So if I want to experiment with prop rotation.... (they are spinnng in right now)
    can I just switch the props.. put in "reverse" and go ??
    I don't feel like messing with the cables yet.
    Once I figure out which way is better then I will switch the cables.
    Yes......
    Be careful its tougher than it looks
    Lake Nasty
    Quote Originally Posted by P Offshore View Post
    Yes......
    It would freak me out.
    I am picturing having to dock like that. Yikes.
    No dock busting.
    on the moon . . .
    not really as bad as you think. I've done it many times just take your time while docking (like you should anyway). I wouldnt do it in a high current high wind area though.
    Heck The raceboat is like that permanantly. Ed seems to like to run it that way but he gets to dock it. i get the sticks when its go-time
    Lake St Clair
    [Ed seems to like to run it that way but he gets to dock it] That's why he is EVIL Ed !!!!!
    Tampa Area
    may be I send a note to Reggie.
    I got the "fastest "V" bottem"
    Going backwards.
    Wouldn't Charlie know vs getting dirty?
    It does freak you out!!! Like they said make sure its a calm day and there arent a ton of people around, you'll throw it in the wrong direction at least once!
    Tampa Area
    Some sound advise guys. I'll let Charlie try it first.. I stay on the docks and call my Ins. Co. increasing my coverage..
    But thanks.. I will do a bit experimenting this weekend.
    Founding Member Edward R. Cozzi's Avatar
    Boca Raton, Florida
    The funniest thing I ever saw was a guy try to run his TRS drives in reverse to try out how the boat performed with the props turning in. The Borg Warner tranny has about a 2.5:1 reduction in reverse. They got so hot they burned the black paint completely off.
    Edward many years ago when I worked at a dry stack a customer winterized his boat at his car dealership. Long and the short of it is they reinstalled the TRS drives backwards and ran the boat in reverse and burned up both trannies. So in attempt to save on winterizing he ended up pulling both motors and replaced both transmissions.
    Charter Member OutlawCowgirl's Avatar
    Topeka, Kansas
    I have always heard spin your props in to win. Well, at least that is what I have been told. I believe I have tried a left prop on my single drive and had to run it in reverse to go forward. I noticed no difference in preformance and I hated remembering to do the oppisite, I was just testing the prop so it was only for a while. Not sure if my going on helped any but I thought I would give my .02. In To Win.
    Tampa Area
    .02's are always welcomed. . In a single drive application left spin or right won't make any difference. The torque is the same. In twins.. generally speaking.. spinning in is a bit faster, spinning out give you a ted more stability. Lot depands on the hull and even if the set is staggered or side by side. Mine are side by side.. so I just want to do a little experimenting.
    NEW JERSEY
    Bravo drives don't care which way they spin so you can "reverse" the props without any concern other than the shifters being backwards. As far as spinning in vs. out, my understanding is that spinning them in produces slightly more stern lift and in staggered apps. slightly more thrust.
    Update
    Tampa Area
    Did a test run today, Spinning out, and going all out with shifters in "reverse".
    Strange...
    The rooster tail was different, wider and taller, a bit slower. (1 may be 2 MPH)
    but seemd to have more stearn lift. I had to trim out more then when the props was spinning in.
    Docking,,,, now that was interesting.
    Not something you really want to do if you want any life out of your drives. If you flex a piece of metal it will fail in X time in one direction/ it will fatigue(break) much quicker if you bend it both ways.
    In the case of some drives the rev set is 1/2 size in reverse.(outboard)
    pat W
    Yes Shifter most drives have an intended rotation. This discussion started talking about Bravos.
    Strange...
    I seen zero gains in speed when going from in to out. Boat feels alot more stable now, and docking is 10x better. I spend more time docking than running WOT, so I keep them turning out.
    Charter Member Griff's Avatar
    Omaha NE
    Strange...
    Spinning in creates more bow lift and also the rooster will go toward the center more and almost create one rooster as gets it farther back. Your results sound pretty typical for changing from spinning in to spinning out.
