Results 1 to 10 of 10
    Hinge Pin Help....
    Seaford, VA
    Before I f it up, how do I get the "cover" off the hinge pins?
    Stainless cover with 2 6 sided screws in the side. Obviously I Have removed the screws but It doesn't want to come off?
    Founding Member Buoy's Avatar
    Apache Jct. AZ
    Quote Originally Posted by Seafordguy View Post
    pic is worth a thousand words.
    What ya got?
    Seaford, VA
    I have been looking for the camera for 30 minutes.
    Bravos, the trim sensor is NOT mounted on the ring, it is attached to the trim rams
    Apache Jct. AZ
    OK, I take it we're still working on the trim down problem.
    This is the trim sensor that I was refering to in the other thread.
    This sets the trim limits up/down.
    I've never messed with it on the Bravo, haven't needed to, but it was a similar settup on the TRS I used to have.
    Again, I am far from an expert on this, but trying to help out with what little I know.
    Charter Member txriverrat2001's Avatar
    on the water
    If your talking about what I think you are - that stainless cover is a high performance hinge pin ... i.e. there is not a pin underneath it......
    number 10 in this pic from BAM
    http://www.mercruiserparts.com/Show_...Steering+Lever
    Seaford, VA
    No, Bouy unfortunately I moved on from the trim problem and figured I'd work on that once I got the engines back in and the drives back on and had that extra weight working for me.
    Quote Originally Posted by txriverrat2001 View Post
    I don't have the trim indicators bolted to the hinge pin like you have Bouy, but I think we are getting closer with that Pic from BAM.
    It has 2 small 6 hexed bolts in it and the center is threaded.....
    The thread is to install an adapter tool and to use a slide hammer
    Seaford, VA
    Damn it.
    Thanks man.....
    The tool part number is 91-63616. It will thread on to a slide hammer
    Seaford, VA
    Thanks MERCMAN - I appreciate the help. I'm sure I'll be back for more in the upcoming days.
