Results 1 to 5 of 5
    XR lower internal compatability with IMCO
    Huntington Beach, CA
    Can anyone confirm that XR or regular Bavo lower internals will drop into the IMCO SC lower? Meaning are the internal parts interchangable so I could buy an XR lower or a regular DWP and drop the internals into the IMCO lower?
    Like this one?
    http://www.diamondperformanceparts.c...cat=258&page=1
    I have a Bravo XZ DWP (SAME Prop Shaft & Carrier AS XR) and I purchased a -2" IMCO Case that came with the shorter vertical shaft.All the internals except the vertical shaft from my lower dropped right in.
    I just confirmed it. Sending you a PM.
    SO Tech Expert/Charter Member
    I live in Holland, Mi. Along the Lake Michigan shore.
    Yes.. they will swap over.. but you will have to reshim it for proper lash and pinion ht.
    Quote Originally Posted by Mr Gadgets View Post
    I am going to have someone work on it that knows what they are doing. "I Hope??"
