I'm tring to find out if anyone might know where I might be able to find a larger injector for my 502 mag mpi. My engine is modified and supercharged, and I think I may need a larger injector to keep up with my fuel needs.
Thread: Larger injectors for 502 mag
Results 1 to 16 of 16
- 3
04-09-2009 01:15 AM
- 72
04-09-2009 08:31 AMIf a 502 has the same injectors as the 496 I have a bigger set. Bought a raylar kit from a guy and he was experimenting with larger injectors. I went with Ray's sound advice and kept the stock injectors! I have not identified them! I believe he bought them through GM.
- 37,391
- Jan 2009
- 207
04-09-2009 09:19 PMCall Mark@ Precision Marine, I'am sure he would know.
- Jan 2009
- JAX FL
- 201
04-09-2009 09:22 PMi have 2 stock sets out of a merc 500EFI, 38psi, all in great shape, i went to a 48psi.... make me an offer if you can use them
- 1,125
04-09-2009 10:04 PMI too have 2 sets of stock off of a 500 efi, but if you are running supercharged you may need higher, I went up to 55lb high impedance. I second calling Mark at precision. if you need stock ones let me know
04-12-2009 02:44 AM
Which injectors do you have? Are they the Kiehin injectors? If so, they do not make any larger ones. You will have to modify the rails and manifold to accept a different style injector. I have done this several times and make it accept up to a 65lb injector. Give me a call if you have any questions. Thanks, Eddie.
- Georgetown, TX
- 426
- 3
04-16-2009 12:43 AMI pretty sure there is a larger one. I seem to remember seeing a ad last year for a 55lb injector to fit my manifold, but I cant remember who was making them.
- 1,125
- Georgetown, TX
- 426
04-16-2009 12:22 PM
It all depends on what injectors are in it now. They used the Keihin injectors until 1999 I believe. There are no larger injectors that will drop in without modifying the rail and the manifold.
Eddie
- Georgetown, TX
- 426
- 1,125
04-17-2009 08:00 PMmine fit perfectly on a 500efi, not sure about the Mag and the fuel rail, just give them a call and see what they say. they were great to work with.
04-19-2009 02:11 AM
Now to be clear, I am referring to the MPI's that came with the Keihin 42Lb(I believe) injectors. I think they used them until around 98, at which time they switched. There are no replacements for the Keihin's. I am not sure about the later year MPI's if there is a replacement injector or not.
