Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 49
    Hydraulic Helm ?'s
    How many cc helm do they recommend for a twin ram set up?
    Check the IMCO website. They have P/N's for the Char-Lynn helms.
    Thanks matt.
    I bought a 230cc Helm and didnt know if it was to big.
    Imco says its 1.5 turns lock 2 lock
    Mine is 3 turns lock to lock with dual rams. 1.5 might be a little sensitive
    sounds like fun
    Registered Anchored's Avatar
    Minneapolis
    If you know the bore of the cylinders, the stroke and the diameter of the rod,
    I can walk you through the math to get the desired ratio. It's pretty simple.
    I dug through my stuff but didn't have any helms. I do have an extra geroter set though.
    Jeff
    Quote Originally Posted by CausinTrouble View Post
    Thanks matt.
    I like a fast helm
    Charter Member Griff's Avatar
    Omaha NE
    I'm about 3 turns lock to lock and would prefer the 1.5. It all depends on what you like.
    I could not pass up this deal. I didnt know the size of the helm but I knew it would work. When I got it I looked it up and its the 230cc. I guess I will have to get used to the fast steering. The boat is a 27' Excalibur and is only 6'6" wide. With 575hp it should be pretty fast and fun.
    Another question: What size hose does everyone use ?
    I used #8 (1/2")on my boats.then #6 (3/8") after the t.
    Thanks Richard
    How do you mount the helm under the dash....With the hoses on the top or can they be coming in the side ?
    Minneapolis
    You can point them any direction you would like.
    Here are a few pics of my Donzi install.
    Jeff
    Attached Thumbnails Attached Thumbnails P5160140 (Small).JPG   Photo-0029 (Small).jpg   Photo-0027 (Small).jpg
    Quote Originally Posted by Richard Crainium View Post
    You can use 3/8 on the low pressure return.
    Minneapolis
    More
    Attached Thumbnails Attached Thumbnails P6120155 (Small).JPG   P6110149 (Small).JPG
    Thanks again guys.
    After I posted, I did some more reading and figured out they can be mounted which ever way works the best for the application. When I start the install I will take pics and post the progress.
    Another question.
    Do the Charlynn helm use an O-ring or pipe fitting ?
    I believe they may be o-ring, but am not sure.
    Pipe would be tapered thread o ring would be none tapered.
