Results 21 to 40 of 49
    Thanks Jim
    I will check to see if they are tapered
    Registered DONZI's Avatar
    Bridgewater Ma.
    Does anyone sell a steering post/shaft Male spline with the popular 3/4 tapered size for these Char- lynn Helms w/female spline inside Helm ??
    It seems most Bezels & Hubs are the 3/4 size offered aftermarket .
    Don't mean to steal your thread C.T.but thought the info might be useful for you also.
    If a tilt will work check this nice piece out.
    Its about half way down the page
    http://www.lathammarine.com/new-products.htm#1
    Bridgewater Ma.
    Nice piece but doesn't fit the budget.Hence trying to adapt 3/4 parts.
    Do an adapter you can use?
    Registered Anchored's Avatar
    Minneapolis
    Quote Originally Posted by CausinTrouble View Post
    Another question.
    Do the Charlynn helm use an O-ring or pipe fitting ?
    You could get them with both. The older ones were usually pipe thread.
    The newer ones are -8 SAE 0-ring boss 3/4-16
    I'm pretty sure the make the extension shaft with the 3/4 taper instead of the spline for the steering wheel end. I'll see if I can find one
    Jeff
    Burden sales in Nebraska has alot of charlinn stuff cheap too!
    Quote Originally Posted by DONZI View Post
    I havent even got that far on mine yet..Still trying to get everything together. Please post what info you find on the post.
    Thanks again Jim and Anchored
    Bridgewater Ma.
    Quote Originally Posted by Anchored View Post
    Jeff
    Thanks Jeff.
    I haven't been able to locate one.
    Are the ones that come standard, helm/strg. post all one assy. ?
    Minneapolis
    Thanks Jeff.
    Page 76 here: http://hydraulics.eaton.com/products...V-MC001-E1.pdf
    If you need more help let me know. Minneapolis is in the heart of this country's hydraulic industry.
    Jeff
    Bridgewater Ma.
    That Catalog hurts my brain ! L.O.L.
    Here's what i have, Char lynn Helm #211 1007 002 w/female spline with a 1" thick dash.
    On a budget, any suggestions w/ part links for a winning combo to fill the gap from helm to wheel ? 3/4 or 7/8 doesn't matter.
    Thanks Ken
    Bridgewater Ma.
    These are priced reasonable from Imco but there is no shaft length dim. to go by ??
    http://www.imcomarine.com/pages/images2/32b.gif
    http://www.imcomarine.com/pages/nev-helm-steering3.html
    Do I need to install the check fittings in the helm and the attach the hoses ?
    Lake Oswego OR
    Thanks Ken
    Donzi, I too, want to convert to power assisted rear (external) hydraulic steering. I see various Char Lynn model numbers listed at the Burden website. Is that 211-1007 the correct piece for a twin engine - dual ram - power steering pump assisted installation? Thanks for any input - Jeff
    Plumbers Crack has a Helm for sale for $150 and I bet it will work for you. PM him he is a member on SOS
    Bridgewater Ma.
    Mine's a single.
    Pg.132 of the Imco catalog breaks down some info for you on CC'S required with rod size & stroke.
    http://www.imcomarine.com/nvcatalog/index.html
    But maybe someone can give you a simpler answer.
    Some more info in this OS.O. thread also.
    http://www.offshoreonly.com/forums/g...helm-unit.html
    Minneapolis
    In order to determine the right helm number I would need to know the bore and stroke of the steering cylinder(s).
    The base part number 211 is correct. This denotes an open center valve.
    1007 is a 4.5 cubic inch metering section. This determines the steering ratio depending on the cylinder sizes.
    If it's a smokin' deal you can buy it and swap out the metering section for the correct one.
    Jeff
    Minneapolis
    Another note for you guys. Since you are converting to full hydraulic.
    Your steering wheel will not go back to the same position every time.
    You could be driving straight and your wheel will be pointed some other direction.
    I put a three spoke symmetrical wheel on my Donzi because of this.
    Jeff
    Jeff
    Lake Oswego OR
    thanks for all the info, guys
    Ok... I got the fittings and some of the long hoses made up today. Going to install the helm this weekend (hopefully)
    Here is another question.. Do I really need a filter ? autos dont run them, most rock crawlers dont have them. Do I need one?
    Thanks
