I had some 5200 left in a tube from a previous job so I decided to use it to coat the exposed wood on a small hole I cut in a bulkhead. A week later and its still very tacky to the touch, Ive had a heat lamp on it for a few days now. I thought about lining it with a thin strip of rubber tire tube, would the rubber bond to the 5200?
Results 1 to 12 of 12
03-21-2009 10:26 AM
03-21-2009 10:43 AM
Porbably not after it has skinned over. They do make a fast cure. If you are going to line it with rubber I would apply a small amount if new adhesive. You can then cover with wax paper or cellofane and tape down so you can continue to work.
Next hole seal with epoxy.
- 37,376
03-21-2009 10:45 AMGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
03-21-2009 11:03 AM
Brownie wrote a few years back that they had a problem with curing and the rep told them to wet it down and that would kick it.
- 37,376
03-21-2009 11:12 AM
I have heard of misting of with a spray bottle of water
03-21-2009 03:35 PM
Use 4200 fast cure next time.
- 37,376
03-21-2009 10:27 PM
I cant beleive you used 5200 after all the drama that was typed about it.....
03-22-2009 12:43 AM
5200 is great stuff if your not in a hurry and you never wanna take whatever you put together apart again.
