It's a little extra work but should pay off in the long run
Started out by taking the boat off the trailer
Results 1 to 20 of 44
03-17-2009 08:25 PM
03-17-2009 08:28 PM
Now it's time to set her down on cribing and make it easier to work on.
03-17-2009 08:34 PM
Man that was alot of sanding! Wore my azz out!
03-17-2009 08:37 PM
Hit some of the filler areas with a couple coats of gel then sanded flat again.
03-17-2009 08:42 PM
Looks pretty sweet Frank! Now was that fun or what?!! makes you wanna be a glass guy huh?
03-17-2009 08:42 PM
Got the gel laid down, so now it's time to sand some more then buff.
03-17-2009 08:45 PM
Your nuts!!!!!!!
03-17-2009 08:45 PM
In the middle of shooting the 1st coat of gel I had a little mishap. The disposable water seperator I was using decided to blow up. So I had to try and hold my pain gun and wrestle the flopping air line to keep it from hitting the wet gel. Man did that ever suck!
Then shortly after that I learned a valuable lesson about how long it takes gel to kick in a pain gun!
03-17-2009 08:48 PM
Make sure you get plenty of mixing cups And a good 5 gal of gel and duratec
03-17-2009 08:52 PM
I have to give a HUGE thank you to GlassDave for all the technical help and guideance. Thank you again Dave! I couldn't have mustered up the coconuts to do it without ya!
03-17-2009 09:03 PMRule one of working with polyesters- Keep a gallon of MEK around.
03-17-2009 09:07 PM
:coolgleamA:You are da man! That looks great!
