Thread: wobble at 45mph
Results 1 to 9 of 9
    wobble at 45mph
    Registered dykstra's Avatar
    Washington, IL
    1996 4x4 454 Chevy dually. Rides fine under/over 45 mph. Soon as I hit 45 mph the truck wobbles. I think I need to have the drive shaft balanced. Any thought would appreciated.
    South Jersey
    When you say wobble I am assuming that you feel the truck and or wheel shake? If it starts at 45 then goes away at a faster speed it is probably a tire more than likely a front.Tire is severely out of balance or has severe uneven wear could even have a broken belt inside tire.Could also be an alignment issue but I doubt it unless drive shaft is bent you have a tire problem
    Quote Originally Posted by Expensive Date View Post
    Like Expensive Date said
    45 mph front wheel balance -60 mph rear whell balance. Jack up front wheels stand about 10 feet in front of truck and have someone spin the tire. if belt is broken in tire usally you will see the bad spot every time it comes around. Usally a bad tire in front you feel in the streering wheel and a bad tire in rear you feel in the ass (feels like the seat is giggling under you)
    Something you may want to look at is the carrier bearing. It is the bearing in the center of the two drive shafts. On my chevy I had play in it, and it caused a vibration at higher speeds. Not sure if you have one, but something to check into.
    I haven't been 45 for a while
    Mark
    Washington, IL
    Quote Originally Posted by Wobble View Post
    haha The wobble is in the steering wheel.
    Quote Originally Posted by dykstra View Post
    Are you sure it's not in his shaft?
    Lower ball joints or idler arm. Or overall steering component wear.
    Carrier bearings cause vibrations- as do missing driveshaft weights. The faster you go, the worse they get. Same with bad tires.
    Washington, IL
    Update. New steering box and stabilizer. Problem solved!!
