Results 1 to 11 of 11
    Help finding block drains on bbcs.
    Lake Nasty
    Got a couple of bbcs with big exhausts.
    Feeling around for drain plugs where they would have been on an sbc. (Behind and under engine mounts.)
    I am feeling around where I can't see.... am I in the right neighborhood?
    Thanks!
    Charter Member ROGUE's Avatar
    Ohio
    On the stbd (even) side of the engine just forward of the starter ( if low). The port side (odd bank) is about the same height, just above the oil pan rail in the middle, aft of the mount. I plumbed mine to a central point and use my oil pump to suck them out, so far so good after 3 years of doing it that way. The pump doesnt seem to mind a little sand at first.
    On the starter side you will find it obstructed somewhat by the dipstick tube also, nice design that. On mine the plugs are longer and cylindrical, I think they are supposed to drain without removing, but they just screw out now.
    Lake Nasty
    Thanks. I wasn't finding by feeling.
    I have a one foot square piece of mirror tile. I think that I may lay it in the bilge and see if I can get a lay of the land that way.
    They are being pulled in the next couple of days... but it has been cold and I have been out of town on business until today. I just want to make sure that they are dry and uncracked.
    Thanks again.
    Fund if they are EFI's the knock sensor may be throwing you a curve. The drains will be in the basically the same spot as sbc.
    Lake Nasty
    Thanks. I am about to go out and explore some more. They are regular carbed and standard ignition system.
    Maybe he/she put some allen plugs in so they're not sticking out. It should be a 9/16" open end....
    Attached Thumbnails Attached Thumbnails 600_Geronimo_14_.jpg   600_Geronimo_17_.jpg
    Lake Nasty
    That helps a lot. Thanks everybody.
    Registered Buckman_4's Avatar
    west michigan along the lake
    If they are dart blocks the plugs are back futher than chevy blocks, the stbd one is almost behine the starter
    Lake Nasty
    Thanks. They have since been yanked. I just wanted to make sure that I got past that cold snap before they were pulled.
    Thanks for the help guys. I am all set.
