Thread: Thoughts on trailer for me..
Results 21 to 33 of 33
02-18-2009 09:01 AM
Green Garden is just south and east of me
02-18-2009 09:59 AM
Mild Thunder, please keep pictures coming as the trailer gets underway, this is great to follow and good luck in your project!
02-19-2009 10:26 AM
The trailer under my boat now is about 44ft or so long. The target is about 41ftt i think.
Once I get underway, which might not be for a month or two, I will definitly post pics of the rehab project.
02-24-2009 01:10 PM
I rebuilt the Target trailer under my Mistress. It was 40' with the drive protector, box tubing and weighted 3625 lbs. I completely stripped all the parts off except one axle and took it to a guy to sandblast, shoot it with etching primer and emron paint and I think he charged me $700. including paint. Took it back home and added leds down the side and across the back. While I was running the new wiring I added reverse lights which I highly recommend. When you are at a busy ramp it really takes all the guess work out for the people behind you what you might be trying to do. Even though your tires look good have the serial # checked to see how old they are. The ones that came on this trailer looked new and after the 3rd blowout I found out there were very old. Don't forget to get bearing buddy's to grease the hubs.
When I bought the Top Gun it had a Manning under it that I wasn't to happy with. The trailer had a 3" bow in it and with the boat full of fuel the axles would bottoming out on the frame. Chris Merrill, Merrill Power Boats near South Bend was a dealer for Trailmaster in Mishawaka Indiana so we put are heads together and had them build us one of there Vanguards to our specs and went with disc brakes. They even went up to his shop to check the bottom of the boat for measurements. The Brakerite electric over hydraulic that you mentioned is the only way to go no matter if you go with disk or drum. When Betty and I went to his shop to pick up the boat on the new trailer the first time I hit the drakes pulling off his lot if we weren't buckled in I think it would have put us through the windshield. Your Target has drum but didn't see if they we electric or hydraulic. If there hydraulic I would just clean everything up with new shoes, add the pump, wire it and your set. The drive protector is a great idea if you have the time. Those look like the same bunks I had. Mine were some kind of hardwood I think they"ll last forever. The most important thing you have to do with the bunks is make sure they go just past the transum a few inches. If you don't have support under the transum it will put a hook in the hull from not being supported. If you do move them try to leave enough room so you can off load with a fork truck in case you get near some saltwater and don't want to dunk the trailer. If you need any help with the LED's let me know what you need. There is store up the road from me that buys allot of overstock parts from the camper and trailer manufacturers up north. I added 4 more LED to each side of mine before I put it up for the winter.
If you are looking for a tool box to mount to the side I found K&W mfg in Bronson Mi near Coldwater that will build any size or shape you want. They carry diamond plate or polished and have very nice locking divises. I store a couple dock lines, grease gun, wax, towels, prop wrench and put my tie down straps in there.
Good luck and keep us posted, Doug
02-24-2009 01:23 PM
These were suppose to load with last post.
