i have a situation i would like some feedback. i have a 388 slingshot hustler with twin 525's, bravo xr sportmasters. i had drive showers installed and the starboard drive, which i never had a problem with, did not want to come out of forward gear. so i thought it was a shift cable. so i making my way back to the marina and all of a sudden the drive just goes. so i making home on one. we pull the boat out and the drive shower is hanging over the tie-bar, the finned cap off the top of the drive is missing, there is a chunk out of the prop blades. the holes for the drive cap and shower are not missing any threads,except for one hole, which had about 1/4" to 3/8" missing threads. the drive is trashed. the cotter pin and pivot pin is missing at the shifter linkage.
my thought is that the shower was not tightened down , without lock tite, the bolts vibrated loose, there was only about 8-10 hours on the boat since install, 3 bolts vibrated out and the 4th vibrated out so far and then the water caught the caps and ripped them out. i would think the shop that did the work would be reaponsible for the parts and labor. any thoughts or ideas of what happened. all would be helpful.
Thread: bravo failure
Results 1 to 20 of 32
01-05-2009 08:38 PM
01-05-2009 09:18 PM
It may have happened that way, but good luck. I have witnessed a similar failure on a race boat. He had nicked a blade and that side kept cavitating and free wheeling. We kept pushing it until it blow the cap off. The shower stayed in place and you could see all the gears. The gears didn't get chewed up but the housing and all upper components were now junk.
You have heard the expression SHiit happens. The cap may have been loose when you assumed it was the cable and continued to run it.
It is hard to say after the fact. Good luck. If the prop was damaged you may be able to make an insurance claim. DEPENDS ON YOUR COVERAGE Good luck either way.
01-05-2009 10:24 PM
OJ got off with alot more proof than you have. You can ask, but unfortunately I don't see them doing anything other than sending you the full bill.
01-06-2009 12:20 AM
Don't know squat about your Bravo but I know the cure reall well.
01-06-2009 02:13 AM
If the bolts holding the drive shower vibrated slowly out like you are thinking, I think you would have had a drive lube alarm go off and would have been seeing lots of lube in the water.
I'm guessing that when you tried to pull it out of forward that it may have moved slightly out of forward gear and then you lost the pins in the shift bracket and it was only partially in gear.
Was it the LH rotation drive??? Another possibility is that the bolts were not long enough to start with. A LH rotation drive puts a lot more stress on the upper cap.
- 3,107
01-06-2009 12:29 PMOne could also summize that the upper gear broke, shot the gear upwards and blew off the top cap and drive shower. While the blades of the prop were still turning the shower smacked down on them.
If it was stuck in gear the floor of the gear may have been broken, then when you kept running it broke the rest of the way.
Was this the port or stbd drive?
01-06-2009 12:59 PM
States in the first post it was the starboard drive. My guess props are turning out so it was the RH rotation drive. I think the drive needs to be torn down before you make any assumptions as to the cause of the failure.
01-06-2009 01:17 PM
If it is the drive that turns left (reverse) it puts a load pushing up on the cap. On my Donzi its the stbd drive that spins that way. The exact same thing happened to me last fall, an i mean exact with the exception of dinging the prop. What happens is through time the bolts can stretch a bit from having the load pushing up and than they will just work themselves out. Thats why there is only thread damage in one hole, it was the last to go. Its a good idea to torque them regularly, I forgot this spring and it cost me an upper.
01-06-2009 04:14 PM
Last year it was an upper for me, this year it's a lower. Bravo's just do this.
- I live in Holland, Mi. Along the Lake Michigan shore.
- 36
01-06-2009 10:14 PMHow about some pics of the drive and what the gears look like. Was it RH or LH rotation? Lot of speculation without a better look.
Usually the top cap on a LH drive will streach bolts and then the gears will break. How the three bolts worked out without it breaking is strange. All three bolts back out at the same time. Still lifting the cap .200" would let the gears self distruct.
If it were RH and the bolts backed out, I could see how only one set of threads were damaged. But how long did it take for the bolts to back out..??
The floors dont break on the newer gear sets. The hubs will crack off the XR gears and the gear splits in two, but it usually just stops.
I use studs to hold the top cap on. I have seen one that the gears broke and streached the studs, but the cap was still there and three of the holes had thread damage.
How about some pics.. that may help.
Dick
01-06-2009 11:28 PM
Top cover is like 25 or 30 ft/lbs off top of my head
01-07-2009 12:57 AM
Also, with a chunk out of the prop, it could have all been caused by a submerged object as well.
01-07-2009 09:49 AM
I was told 25 ft/lbs by my Merc buddy but that was for the older, flat top caps. Not sure if it is different for the ribbed caps used on the XR's. Most drive showers I have installed do not state a torque setting for the top cap bolts but the one shower that did (I believe they were from Eddie Marine) said 30 ft. lbs.
01-07-2009 11:02 AM
That what caused the failure I described earlier. The prop was slipping and ventilating occasionally slipping like in neutral. We would have to back off the throttle and give it a few handfuls to get it to grab again. After 3 or 4 times of doing that it blow the top off.
Our shower had no nicks or damage what so ever. I think if the shower hit the prop it would be evident on the shower. The prop would have to leave a mark.Last edited by MOBILEMERCMAN; 01-07-2009 at 11:05 AM.
- 3,107
01-07-2009 11:34 AMHave't done it myself but I've seen people put studs and spacers on the top cap instead of bolts. Makes sense to me!
