How much work is it to swap out a #5 for a #6??
Thread: x dem #5 to #6
Results 1 to 9 of 9
12-31-2008 07:59 PMHi, Im Dave.. Welcome, glad to have ya.....
- 37,404
04-24-2009 11:04 AMWow, nobody knows or nobody wants to assist Stecz?
04-24-2009 11:09 PM
are you selling the #5 drives
04-25-2009 08:42 AM
Actual crank/prop centerlines are the same if I remember (which is questionable), but the 6 has a setback compared to a 5 (unless the 5 is on a box), so the ideal X is higher.
If it is a driveline setup it's not too bad as the u joints will take the offset, fill the transom & go for it. A plug-in really requires a re-rig to do it right.
I can look at the drawings Monday (or email them to you) if you want.
04-25-2009 09:58 AMGuys- check the date. Almost 5 months ago. And New Years Eve. Stecz was baked.
But good information nonetheless. At the end of the day, you're going to have to re-do the transom. I can't imagine plugging anything that has 6 drives on it. I'd want all the strength I can get.
