Check out the new toy Nordic has in its stable. The former 40-foot Eliminator has found a new home and a future thanks to outboard power.
https://speedonthewater.com/new-boat...d-40-sport-cat
Results 1 to 15 of 15
06-27-2018 07:35 PM
- 37,349
06-28-2018 05:21 PMThat is interesting.
The tunnel is so narrow, and the two hulls so wide, I think you may be able to put two 400's on each side and not have anything intruding into the tunnel.Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- 37,349
06-29-2018 05:46 PMThe other thing I notice, the two hulls are so flat it must really pound in rough water. I hope I get a chance to test one, or read a test on one, in some normal Pacific Ocean rough water. I've never seen a bottom design like that. Not in any offshore cat ever.
06-30-2018 07:27 AM
If I remember the test article...It weighs 7 tons...
- 37,349
07-01-2018 08:33 AMThat sounds about right for a boat that size without a vacuum bagged layup.
I do not know their lamination schedule though. So maybe the weight is elsewhere?Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- 37,349
07-02-2018 08:06 AMI should qualify that. That weight would be with power, ready to run.
07-02-2018 05:46 PM
I loved the original one that came out...But a few years old it was still $600k.
07-02-2018 08:07 PM
Cabin pics not loading.
- 37,349
07-06-2018 06:35 PMWhere did you find cabin pics?
07-08-2018 11:30 AM
For some reason I can only look at 3 pics before boattrader locks up...
Weight with twin diesels 17,500 lbs.
https://www.boattrader.com/listing/2...cat-103346793/Parabellum FJ²B
- 37,349
07-09-2018 08:35 PMI got them to load, but it took time.
That is one odd boat.Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
- 37,349
07-10-2018 07:09 PMI have to believe when they pull off the 400's and put on 350's, 5"s deeper in the water, it will be a really slow boat. That is a lot of additional drag.
