Thread: Taking on water
Results 1 to 20 of 30
    Taking on water
    1999 donzi 28zx twin 350 mags Bravo one's. It's taking water on underway at cruising speed. Can't tell where the water is entering the boat. I've had it on a hose and didn't see water coming in raised R.P.M to 2000 and still no clue where it's entering the bilge.
    Lake Nasty
    The water is entering the boat through the cooling system water pickups. Happy to help.
    Only at cruising speed?
    yes
    Lake Nasty
    Now I have to find it too?
    Ok. Buy a $19 smart phone endoscope camera from Amazon. If you don't have one, get a high candle power flashlight. Take boat to the dock. Don't use the hose connection if you have one, because it might bypass things like your Y pipe, if you have one. Put the boat in the water. Warm it all the way up so that the thermostats open. Stick flashlight and camera in the bilge, tracing the intake hose from your transom assembly to the water pump and block, up to the manifolds, and out to the transom assembly. One side will be wetter than the other at first. Pay close attention to the exhaust risers. Look for light colored calcification stains.
    Confirm it is not coming in at transom. Super double check.
    Because you only leak on plane with engine running: Cooling system; always suspect exhaust riser gaskets and hoses.
    Because you can't see it easily: Suspect something on bottom, between some things, or aft.
    If you only leaked at idle/when moored: Drive bellows, shift bellows, drain plug, hole in boat, other fitting below waterline, bravo block-off plate if through hull exhaust, transom assembly bracket, etc.
    When you can tell what is leaking, take a pic with your phone and post it.
    Registered rschap1's Avatar
    murray lake lowell mi
    I am wondering about belows
    Entering when trimmed...?
    Lake Nasty
    Quote Originally Posted by rschap1 View Post
    As in re-entry?
    Is it possible it's something stupid?
    Like a mechanical pressure speedometer hose?
    Lake Nasty
    My pitot tubes always leaked at the speedo. So to speak.
    You wear Depends to take care of that problem?
    Do they actually make Depends for those wearing Speedo's?
    Lake Nasty
    What you do is just let it hang in a bucket.
    Thanks I\ll check into these.
    You could duct tape your phone, or any video camera you have, into the bilge and go run it.
    Lake Nasty
    Quote Originally Posted by jrdonnellyjr View Post
    If that was confusing, call a marine mechanic. Good luck.
    Too funny.
    He meant, tongue in cheek, he told you where the water was coming from. Now he also needs to find the intrusion point in the boat?
    Wow you are a kind one aren't you??
    Did you get a chance to look for it this weekend?
    Lake Nasty
    Until it is time to not be kind.
    How's the boat doing?
