Thread: Turbine rigging
Page 2 of 8 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 21 to 40 of 159
    was cold out
    #21
    port engine run up early 2008 www.youtube.com/watch?v=S-fBO6Ps-eM
    Here is a picture of the Caliper controller.
    This is activated by a micro switch in the shift which sends voltage to the coil and the onboard air system will apply air to the cylinder which mechanicaly pushes the master cylinder which squeezes the caliper stoping the N2 on the turbine enabling a shift in and out of forward neutral reverse.
    Here is a picture of the 600 amp contactors for one engine.
    The box in the middle is the reverse current relay.
    This when activated charges the 24 volt battery pack.
    Here is the pictures of the Test Cell used in Dynoing
    Turbine Engines.
    This facility is FAA certified.
    When they dynoed one of my Engines they went to lunch During the Pull.
    Turbines are designed to Run for sustained periods at full power.
    Try that with a bigblock.
    g, ck out www.kahn.com hyd.dynamometers for kicks ! how about this ol'vid. very cold, early day in 08 www.youtube.com/watch?v=S-fBO6Ps-eM
    on the moon . . .
    Quote Originally Posted by KnotRight View Post
    just curious, how is N2 decoupled or isolated within the turbine to allow it to be stopped?
    Great thread.
    Good Question.
    The T53 is a "Free gas Turbine".
    The N1 (gas producer) is completly isolated from N2 (Turbine).
    In a Helicopter although I am no pilot The main Rotor can be stopped at ground idle.
    they, being a helicopter has a secondary reduction gear box/trans set up ie: power take off, I believe any 1 else just jump in !
    California
    Great thread.
    You remember what a "Daisy Wheel" looks like that kids play with or old people put in their yards?
    Imagine blowing onto the daisy wheel and it will turn/spin.
    Very similar concept. As the daisy wheel (N2) spins, it is connected to a shaft on a bearing. The N1 GP nozzle forces air onto the PT wheel and in turn spins the wheel and the shaft.
    The shaft is splined to accept an input shaft and thus power is coupled.
    This is the same for the hot shaft and the cold shaft engines. Therefore, there is no mechanical connection and you can stop the N2 from spinning provided you have sufficent means such as a caliper and rotor to do so.
    Rik
    Nice example bro!
    California
    Nice example bro!
    Hey, what can I say. I've been around this for quite a while now.
    Dont let it go to ya head
    Here is the oil tanks. The helicopter has something similar onboard.
    These are 316 stainless.
    These are designed to be mounted directly to the Turbine.
    They hold approx 10 quarts. The Turbines lubrication consists of a
    dry sump with pressure fed bearings and scavenge on all bearings also.
    These tanks have a baffles in them as well as breathers.
    Nice polish job ck.4-leaks now !
    Here is the exhaust.
    Its is of 321 Stainless steel.
    Its is run dry. Thermo wrap (header wrap).
    Also a High heat thermo blanket.
    The way it attaches to the Turbine is with 18 Stainless springs.
    Which allows flex and minimal movement.
    There is also a 1/2 inch gap allowing a venturi to help scavenge
    the Combuster heat and evacuate heat in the engine bays
    There is also a catch can located at 6 oclock that catches any rain
    water and aids in a compressor wash
    Registered bobkatz's Avatar
    Indiana
    Great thread, always nice to see someone doing their own build!!!
    Another run up "Starboard" sweet Kero. ! www.youtube.com/watch?v=B6-BuvVj8AY
    Registered BradH's Avatar
    Atlanta/1000 Islands
    I'm sure you guys have seen it, but he did an excellent thread on the whole re-rig process on the other site...really good read. Brad.
    Yep, just puttin it in another spot for a bump up on Turbine Philosophy and Velocity u-like ? GREAT ! ps: luv 2-go-2 New Orleans and ck. out Al's Ol'stompin grounds koool ! and thanks for postin, keep it a cominon ! --
