http://longisland.es.craigslist.org/boa/4720537447.html
piece of racing history with new engines a great deal
Results 1 to 7 of 7
- Oct 2014
- 3
10-31-2014 02:09 PM
11-01-2014 12:12 PM
Superboat with twin Bravos - $16500 (Port Jefferson)
30 foot Superboat with twin 430HP 400CU full roller smallblocks, only dyno hours on engines, Bravos, two sets props, Warlock Racing hydraulic steering, this is almost a full race boat with twin bolsters and flat decks. The engine hatch is flat, you can walk on it. Superboats are known for winning races and this narrow beam design crushes waves other boats cannot navigate.
the 30-foot Superboat ( named the 30 Tempest) was designed with rough water in mind. The narrow beam, <7 feet, enables the boat to cut through any sea conditions like a knife with the handling characteristics of a much larger boat. Less bottom area and less weight translate into faster speeds, and that 30-foot hull outruns all of our competitors' boats with equal stern drive power. * Note: 8' and 8'6" beamed boats were designed for maximum widths on highways - not performance. The 30 Tempest was almost unbeatable on the offshore racing circuit, and Superboats has won more races with this size hull than any other manufacturer. Three of these race boats, RC MARINE, MEDIA MASTER , and the EXTINGUISHER, completely dominated the A-class from 1991 to 1999 establishing some offshore records that may never be beat. You can fly the tops of seven foot seas and never land wrong., this very rare setup outhandles everthing, . Two sets of 23p props, mirages and blades. New gaffrig gauges, trim in the throttle, new wiring harnesses, all components are LOW HOURS, Please email for photos. Boat is on a steel trailer recently professionally serviced, and is so light can be towed behind a ford explorer. Beam on trailer only six feet.or so including the boat. Very easy to transport and ramp launches like a dream, one person can do it. No expensive haulout fees. Cruises and planes at only 2200 RPM, uses half the gas of the big block twins and finishes ahead of them. Down below are bunks for three or four. MSD marine ign. Blaster coils, soft touch rev limit chipped @6000RPM. The bottom is spotless as are the gimbals and drives. Boat available for viewing at Northeast Performance Marine in Bridgeport. Seatrials available with deposit
11-01-2014 07:05 PM
Nice good price!
- 37,266
11-02-2014 06:43 PMI can't see where it says the year anywhere.
- Oct 2014
- 3
11-05-2014 04:48 PMshes a very babied 1983 that sat without engines for quite a few years, and then after I sold my cigarette, rerigged with bravos. The superboat is a much better boat, lighter faster and more fun to drive. I have the dyno sheets and engine reciepts. The drives etc are low hours. Im in Peru working on a farm, not much offshore racing going on here but my mom has the title signed and ready to deliver
- 37,266
11-06-2014 10:28 AMWhat the heck are you doing in Peru working on a farm? Certainly not something you hear every day.....
When you re-rigged, did you replace the entire tramsom?Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
