Results 1 to 20 of 31
    Wellcraft Nova platform Mod - Venting? Thoughts - also gunwale repair/mod
    Registered HiZ's Avatar
    Oshkosh - Wisconsin
    Okay rocking with a Nova ST and the platform is well. There
    I am torn on liking the platform so I guess it stays.
    I will be taking it off to put on exhaust and will need to cut it for the Exhaust exit
    I know reversion reversion reversion. I am on that. BUT
    We were out over the weekend and I noticed that the platform really needs to be vented to let that air pocket out when in waves
    You can feel the entire deck move when the transom comes down on a wave
    I was trying to think of some type of vent/slot/hole that could go in the back edge or corners to vent this thing
    Might just take care of reversion issues and really will deal with the pressure of "holding" up the transom on waves
    -Click image for larger version.
    Oshkosh - Wisconsin
    Anything coming to mind?
    Lake Oswego OR
    Well, reversion has to do with injected water being pulled back into the engine by negative pressure pulse overlap (my term). Water backing up into your exhaust tips can be reasonably addressed by tip flaps. I've seen a few manufacturers (I don't remember who or what models) address platform "slapping" by incorporating 2 or 3 grates on the surface. These grates can do double duty as service access/inspection ports in case you need to reach down and remove a twig or whatever caught on the drive or in the props. Good luck
    Serious is the BOMB!
    Raise it 6" so its level with the top of the transom, rename it a "bussle" and it should easily add 20+ mph to your top speed and increase the boat's value by 34.285%
    Oshkosh - Wisconsin
    You GYPSY!
    Oshkosh - Wisconsin
    Roger that I have a set of tips that will take care of that issue I just want the thing to be white guy approved.
    I like negative Pressure pulse overlap system dynamics, seems rather catchy. Like that new Daft punk song
    You should really think about converting to a tube platform if you want to stop the slapping.
    Registered rschap1's Avatar
    murray lake lowell mi
    I would say an insert of some sort if not going the tubular route as mentioned...
    Neighbor's Sea Ray had a nice big "vent" in it's center with their logo or something like this one...
    or an aluminum insert with milled slots set in...
    Attached Thumbnails Attached Thumbnails Sea%20Ray%20210%20Sun%20Deck%201f.jpg
    Lake Nasty
    white guy approved.
    Oshkosh - Wisconsin
    Just build one and it turned out nice.
    Hence the powder coating prop question when he asked
    I just like to keep this old bird somewhat original I guess.......
    You can stash the platform in case you want to put it back on. But for the exhaust and low flight landings, the tube one will last and not break the boat...
    Lake Oswego OR
    And of course we all ignore Paul's wisdom at our own peril
    Oshkosh - Wisconsin
    Yeah, Tube is the way
    I was just contemplating it and looking at the thing today
    What to do or not, but I think that tubes are going to be it........
    There is a 28' Powerquest near you that has a nice platform....
    Lake Oswego OR
    As nice a "platform" as the girl on the beach yesterday?
    Oshkosh - Wisconsin
    I NO see
    Near Appleton...
    If you have the talent to build a tube platform, and you have a friend who will powdercoat it for a reasonable price, that's the way I'd go in a heartbeat. You could even make it two small ones, one each side, and leave the middle open if it works for your exhaust.
    How much to build me one ??????
    Oshkosh - Wisconsin
    So bringing this back alive!
    I'm going for the Tube and it's the end of the season so Pull this thing off! Right!?!
    Wrong
    All bolts out and I'm assuming that they used 5200 to fasten it to the transom
    SO, guess what!
    Any advice on how to diffuse the adhesive
    We have tried pressure, jacks, leverage, wedges?
    Short of cutting it off with a chain saw and grinding the rest down I'm kind of at a loss
