Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
    Registered HiZ's Avatar
    Oshkosh - Wisconsin
    Near Appleton...
    Yes It's a few beers drive
    Oshkosh - Wisconsin
    How much to build me one ??????
    What color do you want?
    I'm working on a Jig
    Also just was measuring up a Profile that has a glass/bracket type to maybe go that route
    But I think that tubes are the way
    Quote Originally Posted by HiZ View Post
    So bringing this back alive!
    I'm going for the Tube and it's the end of the season so Pull this thing off! Right!?!
    Wrong
    All bolts out and I'm assuming that they used 5200 to fasten it to the transom
    SO, guess what!
    Any advice on how to diffuse the adhesive
    We have tried pressure, jacks, leverage, wedges?
    Short of cutting it off with a chain saw and grinding the rest down I'm kind of at a loss
    There are several debond materials out there that soften 5200. I've never heard of one being better or worse than others. Some of them are debond 2000, Anti Bond, Marine Formula by Debond Corp, etc. I'd just try whatever your local marine supply store carries.
    Is the 5200 thick enough to where there is room to put a heated razor or knife between the platform and hull? (Or a hot piano wire/fishing line wire leader)? If so, you can saw it off first then remove the 5200 with the debond material.
    Serious is the BOMB!
    Once again, another perfect example for the liberal use of high explosives.
    Oshkosh - Wisconsin
    You still want a platform? Taking orders....................Holding over runway 6
    Oshkosh - Wisconsin
    Yes yiu
    9 Months of this tread.......thankyou
    Did you end up making a jig? If so, what size are you building?
    Oshkosh - Wisconsin
    Quote Originally Posted by CarbonKevlar View Post
    Was there something else going on in here, this place has been sleepy
    Oshkosh - Wisconsin
    90"*18"
    I'll measure when I get back from Boyne......
