I know first hand what abuse a 330 will take. Run them wot until the belts burn off. The magnum have rectangle port heads and big heavier valves. You should add a valve job with new springs, valves and retainers to your list. If it doesn't have roller rockers yet you'll need to add them too. Early ones did not maybe non of them. 370's and up came with crane roller rockers. You can warm that 365 to near 500 with relative ease. Blower adds a whole other can of worms to the process. My suggestion is to have it set up on a dyno. Tuning a blower motor in the boat will be a job. One end of the spectrum its safe and too rich giving up power and the other end is insufficient fuel and it goes boom. Not to mention the added weight on the stern will effect handling. Plus if you add a blower you should add an intercooler too. I forget the exact numbers but its something like add 5 pounds and 200 degrees intake air temp and the net gain is 0.
Its a lot more fun to run a boat then it is to work on it.
Best of luck.
Results 8,861 to 8,880 of 19364
10-23-2016 06:11 PM
10-24-2016 07:06 AM
-1 MPH!
Mornin Ho's !Parabellum FJ²B
10-24-2016 08:51 AM
Bamm! Its been so long I did not even notice until this morning.
10-24-2016 09:23 AM
Mornion hos.
10-24-2016 10:00 AM
Anybody want a Mercedes 560sl?
10-24-2016 01:50 PM
There aren't even any bullet holes!
10-25-2016 06:10 AM
I have four all running and registered. A bit much. I've decided to part with any of them but my truck.
10-25-2016 06:15 AM
This is crazy:
Currently: 4 vehicles and a boat have 24 tires on the ground in service (plus 5 spares), 51 quarts of oil in service to 46 cylinders connected to 32 gallons of diesel and 178 gallons of gasoline. Might be excessive exposure to maintenance.
10-25-2016 06:25 AM
Mornin Ho's !
You'll need that truck for the Zombie Apocalypse....
Off to Jensen Beach Today...gotta install some Hurricane Windows and Doors for a Friend....5 hour drive...through Miami...Who may already be ZombiesParabellum FJ²B
10-25-2016 01:18 PM
Boat put to rest for winter
10-25-2016 08:32 PM
Go Cubbies Go.
- Cudjoe Key FL
- 1,322
10-26-2016 07:13 AM
Mornin Ho's !
Waiting for Daylight in Beautiful Jensen Beach....Got some serious concrete cutting....fitting 3 Sliders into small openings.
Slightly hung over from the Cubs game....Uberstrong Coffee
Looking forward to it Charlie.Parabellum FJ²B
