Results 1 to 11 of 11
    33 OUTLAW A/C install pics.
    Registered ICDEDPPL's Avatar
    Jul 2009
    Aurora Il
    I searched all over and could not find any info on this so I thought I`d post this up for future reference:
    I ran the power from the circuit breakers, and the discharge on the port side in the crease under the bench seat along with the T stat wiring:
    Same side with the supply air:
    I drilled an access hole to see where I was drilling thru and to help feed the lines. The hole is in the solid piece of the boat not the first piece that serves as a cover so unless the cover piece is unscrewed and removed it`ll never be seen.
    4 1/2" hole in the arm rest (dead space) then I fed the line up into the corner (another hole from the top)
    Jul 2009
    Aurora Il
    Looking back the intake might have been better from the bottom, I needed an extra long pickup when going thru the Transom but as I was a chicken **** making a hole in the bottom of the boat transom it was:
    Valve on the inside:
    Extra long pick up and my daily schedule I guess lol
    I had to make some platforms for the pump and strainer to sit on... must be all be under the water level
    I ran the supply line and electric power for pump on the Starboard side thru the bathroom under the couches and to AC.
    Discharge under sink drain:
    The condensation I`m running in the drain for now till I order a CONDENSATOR which takes it out with the discharge. I found out the drains do not empty in the bilge, the water just sits under the boat.
    Hope this helps someone..
    Registered OBNOXUS's Avatar
    New Lenox, IL
    Looks good man !!! wanted to do that to the 36,,,,,sold it instead !!!!!! LOL
    I sure will miss your " OLD " setup though !!!!!!
    Jul 2009
    Aurora Il
    Thanx!
    I`ll bring out R2D2 just for you :-)
    Aug 2010
    Indiana
    Looks good but... is the sea strainer upside down?
    Great job, it definitely looks COOLER
    Feb 2012
    Schererville, IN
    One more step to becoming Cruiser Dan! Love it...
    CHI-TOWN
    Way to go Dan. When can i bring mine over? I need to send my R2D2 out to pasture.
    Aug 2010
    Indiana
    I will miss the R2D2... Everytime it was on the dock... I tried to get the hologram to appear.... always in the morning hours... it seemed to work as the hatch opened and I heard a voice... "alright...who the phuck turned off my air" lol... i'll miss thsoe days. I guess now I have to unplug the boat
    Jul 2009
    Aurora Il
    Quote Originally Posted by teamsynergy View Post
    LOL , always turning off my ac to get me up, worked everytime.
    Cruiser John, I will have a BLACK THUNDER before a cruiser, CHURCH!
    Joe, call AccuMax Inc. for an appointment
    Mar 2010
    Traverse City, MI
    awesome job, thanks for sharing!
