i,m looking for a cylinder head ( iron ) and 2 bl intake manifold ( aluminum) for a mercruiser 4 cyl ,,it,s a 2300 ford ?? any leads or help thanks ,,
Thread: merc 4 cyl,2300 ford
Results 1 to 8 of 8
05-13-2011 06:52 PMIMCO #10- 2009 National Champions
05-13-2011 10:01 PM
Are you referring to the Mercruiser 470?
05-14-2011 12:25 AM
stock stuff or trick stuff? this place rules the Ford 2.3 world http://www.esslingeracing.com/
05-14-2011 08:37 AM
NO not the 470 ,,that has a single v-8 cyl head ,,,this is a reg, 4 cyl ford engine , overhead cam,, ,i have an intake manifold ( to rusted) it holds a two bl holly ,,thank you for your time ,,
- New Jersey
- 39
05-16-2011 10:06 PMMerc never used a Ford 4 cyl, only V8's and that was in the 70's. OMC used the Ford 4 cyl with their Cobra drive. If it's a merc it is either the 3.7 or the GM 3.0.
05-17-2011 12:46 AM
the pinto carb was a holly/webber.... used a lot as a vw bug engine upgrade
05-20-2011 04:23 PM
I TRYED TO E-MAIL won,t go thru..i,ll pm thanks ,,it might be an omc like said ,,
i,m building a 4 cyl modified engine for a friend to run in a series in fla,,thanksLast edited by imco offshore; 05-20-2011 at 04:31 PM.
