I'm putting circulating pumps back on my engines and I'm thinking of buying the the low flat style stainless steel t-stat housings from Diamond Performance #18-1989. Does anyone know if you have to run the 3/4" bypass hose from the top of the water pump to the front of the intake? I looked at the Merc parts listings for the 500hp's 540 Bulldog's and some others and it seems like some have them and some don't. Has anyone used this style t-stat housing before and would this be the best one to run or would the stock style Merc one be better? Any help would be appreciated
Thread: Cooling System
Results 1 to 5 of 5
05-06-2011 07:31 PM
05-06-2011 09:21 PM
You should be fine with that T-stat housing. You can go either way with that bypass hose. Not really needed. I believe that hose is mainly used in cars, so the coolant can still circulate somewhat without going thru the radiator. I dont see a need for it on a boat. Your bypass would be acheived thru the connection of the circulating pump and that style t-stat housing.
05-06-2011 09:43 PM
Thanks, I appreciate the info
05-06-2011 09:49 PM
No Problem. Will you be attending the races again this year?
05-07-2011 08:24 AM
Yes, It was a blast last year!
