Results 1 to 20 of 30
    New engine pics....
    Charter Member txriverrat2001's Avatar
    on the water
    First one on the dyno.....
    Attached Thumbnails Attached Thumbnails DSCN2933.jpg   DSCN2934.jpg   DSCN2938.jpg
    Registered Donskihp's Avatar
    Mar 2010
    VA.
    Nice,What HP?
    Registered MM36SUN's Avatar
    Nov 2010
    Wanatah, Indiana
    What kind of superchargers are they? Never saw anything that looks like them in the flat black.
    Thanks, Mike
    on the water
    Sterling 1550's ..... and PSI Blowers .....
    Registered rschap1's Avatar
    murray lake lowell mi
    S.O.B. ! ! !
    Looks like a monster ! ! !
    on the water
    Yes sir!! Gonna look really bad a$$ in here........
    Mar 2010
    VA.
    What size boat is that? Sure those motors will fit in it?
    Quote Originally Posted by txriverrat2001 View Post
    WoW!! No water spray when you pass, only water vapor!! That will be one super bad rig!!
    on the water
    That's almost comical..... damn skippy they will fit .... nothing a little glass work and deck mod's can't fix.....
    This aint no plug and play.... there is plenty of re-rigging to do.... but that keeps me smiling!!!
    Oh ... and it's a 32 footer....
    Registered Slandrew's Avatar
    long Island,N.Y.
    Holy Hana nice
    Registered jeffswav's Avatar
    Oct 2009
    Millstadt IL
    It looks to be fuel injected. Does it have 16 injectors, 8 on top and 8 on bottom.
    on the water
    Correct.....
    on the water
    All done and headed home .... sweeeet!!!
    Attached Thumbnails Attached Thumbnails IMG00045-20101129-1142.jpg   IMG00082-20101201-1431.jpg   IMG00083-20101201-1433.jpg
    Dallas, TX
    That is gonna be crazy in that 32' Skater! Looks great
    on the water
    Correct.....
    I stand corrected - there are only 4 in the top .... 8 in the intake manifold....
    Spent the weekend taking measurements and talking to our glass guy about new hatches and scoops - we used to "slide" the engines forward when installing them as the blower pulley was just under the deck - these engines are 3 inches taller therefore the pulley is basically getting into the deck...... so out came the saw..... this is where the owner leaves for an hour or so......
    Going to build new hatches and widen/ lengthen or replace the scoops.... not sure yet ... we're also discussing some exhaust changes.....
    We're going to move the forward lip up about 5 inches - these are just rough cuts so we can drop them in to make a pattern for the next hatches....
    Attached Thumbnails Attached Thumbnails IMG_20101205_141930.jpg   IMG_20101205_143237.jpg   IMG_20101205_151657.jpg
    I saw the old Bud Select boat racing in St. Clair with a pair of those engines. I believe that was a 45 footer and they were running down the back straight at 170. Your little boat is going to be a lot faster......
    Big boats rule!
    on the water
    Quote Originally Posted by PatriYacht View Post
    I'm pretty sure we'll never see the redline .... but it'll be a blast anyway...
    Dallas, TX
    If you saw the redline with those motors in that 32...... you would be officially nuts lol
    Registered bobkatz's Avatar
    Indiana
    What drives are you running, looks like 6's but not sure. Any other pics of the boat?
