Thread: 24 transom work
Results 1 to 11 of 11
    24 transom work
    Question
    has anyone ever had the transom redone in a 24 or any idea on what cost should be on this? I will pull motor drive and transom assembly, also want to switch to a bravo cut out.
    Registered afr's Avatar
    Apr 2010
    sw florida
    i would need pictures to estimate the job cut wont change the price any
    Founding Member Buoy's Avatar
    Apache Jct. AZ
    I have a 24' Pantera, and lucky that even though it is a vintage '80, the transom is solid.
    There are many threads about replacing the transom on any boat - the procedure is pretty much the same on any boat.
    Tear out all the old, laminate a few layers of marine ply with a layer of glass, cut new hole...
    Rick (rchevelle) just did it this summer - what more do you need to know?
    Thanks for posting the links guys, The most work was getting to the old one, I cut the deck off, but that 'cuz mine was an outboard with a splashwell, and wanted to reconfigure it anyway. On an I/O, you should be able to get to it from under the hatch, but it sure was nice having it wide open to work on.
    Apr 2010
    sw florida
    bobcat inboards are differant then the outboards transom still they take 4 to 6 days to do one complete depending on the rip out
    Homeless in West Mich
    Quote Originally Posted by afr View Post
    Just curious where is your location ?
    Apr 2010
    sw florida
    punta gorda fl artie
    1726 steadly ave 33950
    http://www.allfiberglassrepairs.com/
    Thanks found a place locally that has agreed to fix it and wants it as soon as i can get the motor drive and transom assembly out of the boat, now looking for bravo extension box thanks.
    Update
    Cool
    Stopped in to check on my boat today. I am really impressed with the work that has been completed. Old transom removed new transom just finished and going to be installed tomorrow morning, should have it back this weekend if all goes well.
    Registered tsp's Avatar
    Toronto
    Quote Originally Posted by Liberator 211 View Post
    How much are they charging for the transom redo?
