Results 1 to 9 of 9
    Trailor Bunks and blisters
    Registered jeffswav's Avatar
    Oct 2009
    Millstadt IL
    I started a thread in the fiberglass section and we were talking about the problem with the bunk carpet causing blisters in the gell. After I repair all the blisters and wet sand I do not want the blisters to come back. Has anyone tried any of the plastic wood products for bunks?
    Registered OBNOXUS's Avatar
    New Lenox, IL
    My 272 did that and it was blamed on no barrier coat between glass and gel.
    It was fixed under warranty and never came back.
    Oct 2009
    Millstadt IL
    Well my boat is a 94 and I think the warranty is well expired. They were there in 98 when I bought it and they have not gotten any worse. But most of you here are like me I am looking for a couple more MPH.
    Aluminum
    http://www.thehulltruth.com/trucks-t...num-bunks.html
    You can see them in my below pics
    Attached Thumbnails Attached Thumbnails bracket2.jpg   bracket4.jpg   transom.jpg
    New Lenox, IL
    Im just saying its due to the construction more then the bunks,,,,, they had problems in the mid 90's
    Im sure they are not stealing 2 mph from you though.
    My buddy has a 236 and has a huge hook in it,,,, thats hurting you more then anything.
    I had my 272 blueprinted when the blisters were being repaired and picked up 2-3 mph
    Oct 2009
    Millstadt IL
    The boat is running 72-74 MPH on the GPS. This topic started because I have been enquiring about blueprinting the hull and removing the shingles (hooks). Some people think I am so high out of the water that that have no effect. Here is the only pic I have at full speed.
    Homeless in West Mich
    Jeff , seeing that your boat is a 94 and has taken this long for blistering to appear i can honestly say that i do not feel that this problem involves the construction of your boat . Osmosis / Hull blisters most likely in your case are caused because of the moisture retained in the carpet on the bunks because the water enters the hull through the jell which creates preasure behind the jell hence Blistering . Jeff i have seen this happen on Skater's older then a decade along with Cigs , Fountains , ext ext . Jeff i could be wrong but..............and jeff trailor ? Just kidding ha ha ha ha .
    Oct 2009
    Millstadt IL
    Oh, I see you are now my spell checker, I think you have your work cut out for you!!
    Oct 2009
    Millstadt IL
    So, getting back on topic here. Anyone use the plastic wood products for bunks?
