What is the best flowing USCG air cleaner available for someone on a budget?
This is what I'm working with now, original equipment on a 420 Mercruiser...
Results 1 to 11 of 11
07-14-2010 09:49 AM
- Cudjoe Key FL
- 1,323
07-14-2010 11:17 AMIt might run better if the coil wire was on. Just kidding, bustin your chops.
07-14-2010 05:00 PM
That looks like similar the Barbron(sp?) I have on mine and it flows well. I did back-to-back runs with and without the flame arrestor and saw no difference in speed.
07-14-2010 10:57 PM
If you want to wake it up put some exhaust on it. That looks like stock 4". It was original on 370's. 420's came with a bigger exhaust. That is the most notable restriction in your package.
07-16-2010 11:18 AM
I'll send the coil wire
07-18-2010 07:16 PM
What he said. The 420's should have came with GIL manifolds. Those heavy cast iron stock merc ones you have do nothing for Horsepower. They use a common plenum, so the exhaust basically dumps into a big open chamber. Gil, stainless marine, and of course headers, have individual runners for each cylinder.
As for the Flame arrestor, what you have is fine for your engine. Just keep it clean. I clean mine with brake clean which works good. Of course take it off first before spraying it.
07-20-2010 08:50 AM
I see your engine has a Wieand X-celerator intake on it. That's original equipment. If it has Crane gold rockers it's definately a 420. Someone changed the exhaust from the original.
Big boats rule!
