Results 1 to 14 of 14
    Littlefield Vs Mooneyham
    ok so which one will put better numbers on the dyno tomorrow?
    1 new 1471 littlefield magnesium hi helix stage 3 stripped for offshore gas by mr. littlefield himself or....
    1 new 1471 mooneyham magnesium hi helix stage 3 stripped for offshore gas by mr. mooneyham himself
    on identical motors
    www.41apache.com
    After extensive research and looking at raw data I have one question.....
    Where's the dog ?
    Where's the dog ?
    pretending..
    www.41apache.com
    Dallas, TX
    same outlets and inlets on the blowers? I would guess the same (within 10hp or so)
    Registered Trim'd Up's Avatar
    STL, on the ILL side
    My thoughts as well. They are just different takes on the same thing.
    The real test will be when you then swap them out on the motors and retest My guess the one with more Motor BLING
    Registered endeavor1's Avatar
    Jul 2009
    LOTO
    Quote Originally Posted by viperfitness1 View Post
    on identical motors
    The PSI blowers that you are gonna buy.......
    Race boat must be getting closer huh? Post some pix of that bad boy
    Dallas, TX
    on identical motors
    what are you running for intercoolers? You gonna keep the same ones when you switch the PSI's?
    soon my friend soon...
    www.41apache.com
    actually Lee and Monty worked together matching these blowers to each other.. who knew they are only 20 miles apart....
    did not run today, the motor from sat still hasnt finished
    hopefully first thing in am
    www.41apache.com
    yes
    www.41apache.com
    how about testing 16-71 or 18-71 then a few smaller like 8-10-12-71 it woud be interesting to see the numbers i find it hard to believe all that blower hanging off the rear of a nitro engine is doing much but i could be wrong
    I'll put my money on the littlefield
    be interesting to see a helix on gas, I dont have any experience with that combo yet.
    I know on alky a helix retro made over 120 hp over a standaed rotor
    Quote Originally Posted by boostbros View Post
    On an alcohol motor the 16 and 18's do a lot better than a good 14
