Results 1 to 7 of 7
    Early Bravo gimbal housing help....
    Registered gcarter's Avatar
    Dec 2008
    Leesburg, FL
    My Bravo was built in '87 and is one of the first offered and uses the anodic stove (square) bolts in the two lower positions.
    The bolt holes in the gimbal housing are "inside" the housing O-ring seal and will leak water if the bolts aren't sealed.
    It's been too long since I've done one of these and don't remember what I did the last time.
    Any suggestions?
    See items 41,42, and 43 below and in a small box...
    Marine sealer such as 4200... Jamie
    Charter Member ROGUE's Avatar
    Ohio
    Yeah, 4200 is what I use. Dont use 5200, makes it real hard to ever get them off.
    Registered Throttle Fever's Avatar
    Sep 2009
    Northwest
    Didn't they have a rubber washer that went on the bolt on the outside?
    Registered inbetween's Avatar
    Mentor, Ohio
    Mine are from '88 and have the same style. Call Ron Bender at JR Marine. http://jrmarine.com/ Number is on the bottom of the page.
    Ohio
    Quote Originally Posted by Throttle Fever View Post
    Yeah, but they had a tendency to squoosh out when the bolt was tightened.
    That rubber washer didn't really seal it up. It was more of a buffer in-between the anode & the bolt's flange on the outside. It would have done little if anything for the sealing of the bolt thru the transom.. Sealer is a must to be safe.. Jamie / Lakeside
