Results 1 to 6 of 6
    Swapping 502efi for 525efi
    Registered endeavor1's Avatar
    Jul 2009
    LOTO
    Converting a Black Thunder from 502/540efi engines to Merc Racing 525 efi. Does anyone know of common issues that may arise in this swap. I m worried about electrical connections and sending units to the new livorsi guages. Everything worked for the 502/540s.
    Any help would be great!!!!!!!!!!!
    Thanks in advance, JCB
    I have heard lots of gauge trouble. Need a certain cable to convert. Maybe the new Livorsi's will be compatible already.
    please be so kind to inform me if someone has mercruiser 600 sci and also where I can download users manual for it and buy used engine for reparation .
    Thanks in advance
    Registered Bradz's Avatar
    Illinois
    Should be plug and play. Standard wire harness plug worked fine on my Skater that was converted to 525's from big blower engines.
    SO Tech Expert/Competitor/Charter Member
    Downtown Ruby, MI
    If you had a 10 pin harness and the new 525 has the 14 pin I have some adapter harnesses.
    The Michigan Madman
    What are you doing with the 540's?
