Results 1 to 20 of 31
    Installing bungs for sensors
    Lake Oswego OR
    I am looking at installing bungs for O2 sensors in the future on my motors. I have Stainless Marine manifolds and jacketed pipes. Is there some place where it is feasible or possible to install these. I understand that water at the sensor location is death to these sensors and may necessitate dry exhausts. Any input would be appreciated. - Jeff
    Where the summer never ends
    All the way on the bottom of the runners should be no water..but i am thinking HIGH TOURQE III ...which ones do u have from SM ??
    Griswald installed them on his Stainless marine tail pipes. He can help you with it. Send him a PM if he doesn't see this post.
    Lake Oswego OR
    thanks DARE and Jim. BTW I don't have that type of Stainless Marine header. I really appreciate the help.- Jeff
    Georgetown, TX
    I put one on both risers
    Boat-less...
    Quote Originally Posted by Griswald View Post
    Nice, how did u do that with in the water pasage ?? Intresting and looks perfect !
    It was welded on inside and outside.
    Lake Oswego OR
    very smooth- thanks for all the input guys. - Jeff
    Registered scottw's Avatar
    New Jersey
    My friend sent his back to SM to get his installed.
    Lake Oswego OR
    thanks Scott
    Georgetown, TX
    Did you ever get these installed?
    Boat-less...
    Lake Oswego OR
    No, I've been way sidetracked with other "stuff". Thanks for checking though. - Jeff
    Registered htrdlncn's Avatar
    Jan 2010
    Lake Travis
    I took my jacketed pipes to Muffin Muffler here in Austin, they have done some custom work for me before, $50 to install the O2 bung , looks factory.. Any good fabrication shop can do it and for a WHOLE lot less than the manufacturers of the headers..
    You would be amazed what a good fabrication shop can make/fix for you ...
    Its the first thing I look for when i move to a new place.
    Quote Originally Posted by htrdlncn View Post
    Do they weld in a pipe to get to the exhaust through the jacket?
    The pipe you speak of is an female threaded adapter.
    Registered Rookie's Avatar
    Grand Rapids, MI
    A little late to this post, but this is where I put my bungs in. Griswalds are in the ideal location, but this is where I could get a weld on the front and backside. In the first pic you can see the bungs I made. (I made 4, one for each pipe) And after you are done welding just grind down the weld, sand and polish.
    Where Dardevil mentioned is where I have my EGT probes.
    i got to tell you guys i did mine and got a a/f box . i dyno my motor 97jets all around running in the boat i had to down size 86 in pri 89 sec now my a/f 12.7 3000rpm12.5 wot pick up 4mph and the motor runs great. before i did this she loaded up and smell raw gas here is my a/f box that i use http://www.amazon.com/Innovate-LM-1-...f=pd_rhf_p_t_4
    Registered PayCheck's Avatar
    Feb 2009
    The doghouse, again.
    Good advice, Bob.
    Quote Originally Posted by PayCheck View Post
    Good advice, Bob.
    , Thanks
    Lake Oswego OR
    so, what would the technical term for the opening into which the fitting would be placed????
