Results 1 to 17 of 17
    Pulling a Bravo Drive
    Dumb question, how do you pull the drive to grease the u-joints without all the drive lube in the bottle draining out? I thought there was supposed to be some sort of valve to stop the flow when the drive was slid back, but I had lube squirting all over the place, so I slid it back into position for now.
    ________
    Where the summer never ends
    If u pull it all the way, it should not drain..the valve will close in the gimbal !
    I had the drive about 3/4" apart and all I saw was a stream of lube shooting out. No valve of any kind. At least not pictured like in the Merc manual.
    I gotta quit waiting till the last minute to do this stuff, LOL!
    ________
    You stopped at the worst place. It will keep flowing until you pull it off some more.. It will stop flowing once the drive has cleared the valve
    OK, rookie mistake then. I'll try again.
    ________
    Thanks DD and Jim for your quick response. Drive is off, that bitch is heavy. No BP oil spill in the garage either.
    Another quick question....Why does Merc have so many different greases? I have 2C4 in the gun and was going to use that? Is that OK?
    ________
    There is a grease for every application.. They make a spline grease that is good for u joints too. The 2 4 c is really a general purpose grease for cables installing impellers and such. I would not use it in u joints. Use the spline grease or equivalent some High pressure High load grease Mercs is a dark blue... My favorite is Special lube 101 it is light green.. I use that on splines and all o rings and studs during assembly.
    Mechanicsville VA
    Hey...maybe you should change your screen name???
    couldn't resist
    couldn't resist
    Me? To what?
    Mechanicsville VA
    Me? To what?
    NO...the OP.
    MacGyver, you know the TV show, the guy that could make/do/fix anything with the lint in his pocket.
    NO...the OP.
    Not just lint.....I still need duct tape, a paper clip and my swiss army knife
    Just want to do my drive correctly
    ________
    Well, I shot some in the u-joints already Guess I'll pull the drive and get the better stuff after this weekend. If you use Special Lube 101 on splines, can I use that on everything??......trailer bearings too??
    And I thought grease was grease. Guess not.
    ________
    Sorry, did not follow ...but glad u got it done.. !!! MAC GYVER ..hahaha
    Hey now, be nice
    ________
    I looked since I fast answered. Merc also has a gimble bearing u joint grease get some of that for your grease gun. Use the special lube 101 on the o rings, splines, studs and prop shaft. You can use the merc grease on wheel bearing if you want.. I have a separate grease gun with the citgo waterproof bearing grease for trailers.
    Thanks Jim, I greatly appreciate the info!! I guess I should follow what Merc specifies.
    ________
    I always use the MARINE grease..for all of it on my boat...even the bearings on my trailer..never had an issue !
    U know , merc buys this also and has color added on most of it !
