Results 1 to 14 of 14
    Has any1 plugged of oil fill on TRS drive
    Competitor Whoz Your Daddy's Avatar
    Tuckerton NJ
    Has any1 ever tried to plug /unhook the filler that connects the drive to the resevior? My main concern is I think thats the only way the drive has to vent? Tired of drive oil in bilge after race.
    TEAM 531 WHOZ YOUR DADDY OFFSHORE RACING
    www.WHOZYOURDADDYRACING.com
    OPA THE JERSEY BOYZ
    It needs to vent. Some people use a bottle instead of the one that came with it.
    I suggest you not fill to the line on the stick. Just set level to touch the bottom of the stick..
    Tuckerton NJ
    I have tried to put in just a drop to touch the dipstick but seems to still puke after a hard run. Guess i will try bottle next. Thanks
    OPA THE JERSEY BOYZ
    Where the summer never ends
    If u take the little breather out on the inner transom plate and stick in a nipple , then add a hose and on that hose u add a bottle about 1 foot away from the original reservoir u be fine !!!!! Then only fill the res. so u barley see oil on the bottom of the blastic glas !!!!!!
    I hope u are listening !
    Tuckerton NJ
    Scott
    Was thinking about just adding a longer metel tube? Does that thread in? or could run hose to puke tank i guess
    thanks
    OPA THE JERSEY BOYZ
    Quote Originally Posted by Whoz Your Daddy View Post
    Scott
    thanks
    The breather on there is threaded,,and yes nipple , hose ,, to a puke tank,,but still dont over fill the res. !!!!!
    TRS,SPEEDMASTER...are not like bravo's ..they don't eat oil, they produce pressure !!!!
    I learned that,,lol...had oil in the bilge all the time untill a friend of mine ( YES I HAVE SOME ) told me this and he knows SSM and TRS drives very well !!
    here is a pic where u see part of the hose...couldn't get it off, so i cut it..lol
    But basicly from there to a bravo res. is what i had...but i used that res..as a puke tank !!
    Tuckerton NJ
    great pic scott I will do tomorow. Do u think i need a resivor? the drive holds 20 gallons lol
    OPA THE JERSEY BOYZ
    If the drive holds 20 gallons..something is wrong..hahahahaha
    well, i used a bravo res ( the little square one ) on the other side of that hose .
    and filled the stock res. , just so i could see oil on the bottom of the sightglas..the Bravo res. was good because what ever it puked in could run back in to the stock res. !!!!!!!!
    get my point ???
    Bradenton Fl.
    Scott
    thanks
    Take breather out and put a six inch nipple in res, put coupler on nipple and put breather back in ( its 1/8 npt) This works 90% of the time. If your really beating the boat put a support on the extension so it doesn't snap off. Like scott said if you have 20 gals. in a TRS You must have a very large res.
    Tuckerton NJ
    the 20 gallon is a joke they hold alot of oil. Thanks
    OPA THE JERSEY BOYZ
    Are you running a drive shower? I added one that feeds off of the outlet of the raw water pump to my cigarette and it cured the oil problem .Heat causes expansion of fluid and air which = your situation.
    Lake Oswego OR
    good idea DARE !
    good idea DARE !
    Yep..sometimes it just hits me ...LOL
