Page 2 of 2 FirstFirst 1 2
Results 21 to 34 of 34
    Check your pick up tubes before you install the rebuilt engine. Don't assume anything.. Nothing is worse then fixing the same thing twice.
    nothing in pick up tubes. replaced #6 exhaust valve and put in two new billet fuel pumps and guages. fuel pressure is good at7lbs at idle and 6lbs at running. Once again engine got up to 2000 rpm before port motors rpms fell off. Getting frustrated now and I know the engine builder is also.Next move is taking engine out and putting it on dyno. Don't know what else to do.
    So fuel pressure is stable during power loss? Are all other gauges normal? Did you try disconnecting the tach? Have you tried a jumper lead to the ignition on the engine? Can you check to see if the timing is stable during power loss? I hate phantom problems...Good luck.
    Feb 2009
    Bettendorf, Iowa
    good fuel pressure... low volume?
    Yes, fuel pressure stays the same. I did try diconnecting the tach. I have not tried a jumper lead to the ignition yet. Timming has been checked and seems to be fine. This one is driving me nuts. I will now be going on week #3 and in NJ our summers are too short to have this kind of problem. Thanks for your advice. I will try jumping ignition
    Georgetown, TX
    will it rev out of gear?
    Boat-less...
    Quote Originally Posted by Griswald View Post
    Yes, but seems a little sluggish..
    can't be... if the pump or the float bowl runs out of fuel, the press goes to zero. i think i would shoot a timing lite at it ... if it was retarded like crazy it would do this...
    Feb 2009
    Bettendorf, Iowa
    Quote Originally Posted by stevesxm View Post
    good point didnt think of that
    Found the problem... Switched Tachs and the engine giving me trouble, came to life. The other engine developed the same problems the previous engine did. Seems the tach was bad and causing some sort of short. Brand new Livorsi guages..... Well looks like I'll be back boating this weekend. Once again thanks to everyone for all your input... Have a GREAT boating season and be safe..
    Great,, Thanks for following up with the answer to your problem
    Quote Originally Posted by Xtreme Air View Post
    WOW, I'd never expect a bad tach to cause this kind of trouble. Thanks for keeping informed.
    ________
    Mar 2010
    MD,,,chesp
    hate to sound stupid, do you have exhaust sensors, My bud Big Block has a bad senor..that did it///
    Quote Originally Posted by Bear442 View Post
    No exhaust sensors. Just went through every thing else. Engines always sounded fine. Swithced the tachs and bingo! that was it. Ran boat yesterday and all was well. Put in the old gaffrig guages and every thing seems to be working fine.
