Results 1 to 14 of 14
    found water in outdrive
    bar on da water
    i came in from a hard ride sunday, raised the hatch and gear oil everywhere. the next day i drained the drive and there was about 40%water to 60 oil of what was left in the drive. PanteraM24 ssm3 drive. What gave!!! Thanks Jaime
    Where the summer never ends
    Quote Originally Posted by JAIME View Post
    99% prop shaft seal !!!!!!!
    Tampa Area
    99.9%
    I had same problem on the Bravo XR, but luckly I had virtually no water in the unit. I cought it just in time.
    bar on da water
    thanks ill look into it. Dare your everywhere, hope something good works out with P.P. for ya, great lookin boats.
    Thanks..lol
    Registered tsp's Avatar
    Toronto
    It could be the bellows. When was it last changed? I had the same problem last year. Mine looked ok, but when I inspected it closer there was 2 small holes. Did you have any water in the boat as well?
    Quote Originally Posted by tsp View Post
    How would the water get in the drive true the bellows ????????
    Toronto
    Leaks past the main seal on the drive shaft.
    The upper has only one seal it holds lube in. It does not have two seals one of which holds water out like a prop shaft.. So yes, if water is in the bellows it WILL get in the drive..
    Toronto
    So its the seal , not the bellow...it will not help the drive to change the bellow !!!! lololololol
    Seal could be gone too. But that's another issue. He's getting water in the lube not losing lube. Water gets in the bellows and leaks past the seal. The seal is not meant to keep water out.
    mmmmmmmhhhhh, did not know that..THANKS..know i learned something too !!!!
    CHECK YOUR BELLOWS ..LOL
    Toronto
    The things you learn when you own an older boat.
    That comment would make a great t-shirt
    fishing line on the prop shaft?
