Results 21 to 40 of 51
    Might be a good time to change those hubs. Oil bath is the most durable, but immersing them is a problem. My favorites are the one's that use grease but you pressurize with a little basketball pump and needle.
    Serious is the BOMB!
    Consider it a blessing, going down the road and get a flat with no way to get the wheel off.... might be a good time for a little PM on the rest of the wheels....
    Where the summer never ends
    WTF is PM ??????
    Preventative Maintenance
    WTF is PM ??????
    That explains everything
    You beat me to it. I was going to say grind it off.
    Rick, just thought about this again. U can also take the bearing out , take the hole wheel off including the brake drum, then take a grinder and cut the stud off in the back, then just dis asamble and throw in a new stud !!!!!
    I watched my grandpa freeze one once, then hit it with a big punch and inertial amplification device and it snapped right off....
    Yep, stick the trailer in the freezer !!!!! GOOD IDEA
    Can of freon. Works wonders.
    U all know , that u can make a simple task VERY VERY hard !!!!!????
    Feb 2009
    Bettendorf, Iowa
    you could remove all the valve stem caps and slide another trailer under them.
    OK, the hub covers screw off from the outside, still not sure I can get the caliper out of the way with the wheel attached, but we shall see.
    For the alignment problem...........
    Should these be level, or at least pivot freely?
    The tire that is wearing the outside is 1/4" more spacing hub to hub than the other side, that would explain the outside wear, if these are stuck like this??
    first right, then left, the pen in the pic is front on both sides.
    Oh yeah, they are disc brakes, Kodiak., reliable oil bath hubs, and yes, the covers unscrew.
    Quote Originally Posted by rchevelle71 View Post
    YES,,they need to swifel FREE and actually should be a driangle hanger and level !!
    Also check the bushings on the leave springs..if they are gone,,problem.
    The reason why i am converting to torsion axles !!!
    And next time have your wife take the pix,,,nobody wants to see your ugly legs or those old shoes..lol
    Those are my work shoes, they are famous around the hood, sometimes I even forget I am wearing them, and wander to the store with them on
    Quityerwhining...
    Trying to save this one for a friend...
    Attached Thumbnails Attached Thumbnails DSCN8613.jpg   DSCN8616.jpg   DSCN8617.jpg
    Quote Originally Posted by Madpoodle View Post
    Quityerwhining...
    HOLY PHUCK,
    the aluminum is all eaten away
    I would sell that one for scrap
    Jul 2009
    PALM BEACH FL
    Wow, Rick has ScottyB been doing your trailer maintinence ? Looks just like the trailer under the race boat...Good Luck ! Mike P.S. Dont get mad Scotty !
    Quote Originally Posted by ricochet myk View Post
    LOL
