Results 1 to 13 of 13
    Superstock Rules
    Can any one tell me what are the rules for the superstock class?
    What are lenth and width allowed?
    Is their a rule book with specific information?
    Minimum weights etc.
    Thanks.
    you will find every thing you need to know on the SBI OSS or X cat web sites
    Founding Member Wardey's Avatar
    Palm Harbor, Florida
    Hey Lee !!!! Hope all is well. Dave
    Here you go : http://www.superboat.com/docs/2010%2...%203-23-10.pdf
    Only two defining forces have ever offered to die for you: Jesus Christ and the
    American Military. One died for your soul, the other for your freedom.
    Sarasota, Fl
    In OSS the rules are 28'-32' with no variance.
    Max Beam is 10'6"
    Max Tunnel is 60"
    28' - 3,800#
    29' - 3,925#
    30' - 4,050#
    31' - 4,175#
    32' - 4,300#
    with no variance.
    Ryan Beckley
    Width
    Thanks Ryan
    Im looking at tunnel width rules!!!!
    60"
    Where the summer never ends
    Quote Originally Posted by Ryan Beckley View Post
    Max Beam is 10'6"
    Max Tunnel is 60"
    28' - 3,800#
    29' - 3,925#
    30' - 4,050#
    31' - 4,175#
    32' - 4,300#
    with no variance.
    What about engines ??? 2 or 3 ???
    2 engines.
    Quote Originally Posted by sugarstick View Post
    2 engines.
    Thanks !!!!!
    Competitor
    Jan 2009
    Florida
    7.
    SUPERBOAT STOCK™
    7.1.
    ENGINE CRITERIA
    7.1.1.
    Super Stock Class is based on the specifications of the use of the 1998 and up Mercury (2.5 liter) 280 HP, 153 C.I.D. offshore race engine. Alternate engine manufactures or older Mercury motors must submit engine data to the SBIP technical committee for approval.
    7.1.2.
    Canopies are not required however strongly emphasized. Those with canopies must comply with the SBIP Cockpit Guidelines. Contact the SBIP office at 305-296-6166 if you need information on the cockpit guidelines.
    7.1.3.
    All outboard motor power heads must comply fully with all specifications, as provided by the manufacturer (i.e.,stock as produced). No special parts or interchange of parts will be allowed unless approved by the SBIP Chief Referee in conjunction with the SBIP Director, in order to pass a post-race inspection. These specifications shall include not only the powerhead specifications but also the complete
    2010 Technical Rulebook 3/23/2010 Page 57 of 64
    specifications pertaining to the center section, lower unit and exhaust system. The year of the power heads must be declared. Only the following modification shall be permitted.
    7.1.4.
    Balancing and blueprinting are not allowed. Any engines that were used in the 2003 season are Grandfathered in, and can be used as spare engines in the 2004 season. The serial number must be given to the SBIP office by February 1st, 2004.
    7.1.5.
    A lightweight facsimile of the production cowling may be used, however the production of identification decals must be used. No alterations to the air flow.
    7.1.6.
    Lower units – any OEM gear ratios are allowed. Nose Cones are allowed.
    7.1.7.
    Aluminum flywheels are permitted on 1997 and older. No modifying or lightening flywheels allowed.
    7.1.8.
    ECU boxes may be reprogrammed.
    7.1.9.
    Any reeds are allowed as long as stock reed cages are used.
    7.1.10.
    Updating of equipment is permitted, backdating is not allowed.
    7.1.11.
    No turbo charges or supercharges allowed.
    7.1.12.
    Petroleum based fuels only, octane inducing additives are not permitted.
    7.1.13.
    Minimum overall length of 28’ with a maximum of 32’.
    7.2.
    Minimum weight: 28’ … 3,800lb
    29’ … 3,925lb
    30’ … 4,050lb
    2010 Technical Rulebook 3/23/2010 Page 58 of 64
    31’ … 4,175lb
    32’ …4,300lb
    7.2.1.
    Minimum weight will be determined at the end of the race. Included in the weight, engines, residual fuel, drives propellers, fixed ballast, all hull drain plugs removed, and safety equipment as stated in the racing rules. What is not included in the weight, crew, life jackets, helmets, bilge water, and ballast water.
    7.2.2.
    A race team is not permitted to change a boat during the racing season, except if it is damaged, sold, stolen, or physically unable to race. Boat must meet class rule specification.
    7.2.3.
    All propellers must be approved by Superboat prior to and after the use during and official race. The criteria for propeller approval is that a lab finished propeller must be inspected with the receipt of the amount paid. Showing the manufacturers suggested retail price. Each lab finished propeller may not exceed $2,000.00 dollars and must be made available to any racer within a 30 day time frame. If at anytime the availability goes behind the 30 day time frame any existing propeller will be disallowed for the rest of the season or until such time as the manufacturer can meet the 30 day time frame.
    7.2.4.
    Current list of approved propellers, all other propellers must be approved by the SBI Official prior to use.
    MERCURY, HYDROMOTIVE, THROTTLE – UP, AND MAZCO
    how's this going to work with OSS basically mergering in with SBI. Who's rules are you guys going to follow? From the schedule it looks like they're all but one ( Biloxi) Sbi races which would mean that SBi rules apply?
    hence superstock rules are governed by SBI and DW's new boat is going to be legal?
    Why not adopt x-cat and move in a more unified way?
    Competitor
    Jan 2009
    Florida
    Dave ,
    Not really sure if there is any differance in the OSS and SBI stock class rules, but I'm sure Ryan could answer that better, he is more fimilar with the rule then me. I know we took a look at all the class at earlier in the yr when we merged and pretty sure they were the same.
    well reading what you posted for SBI and what Ryan posted for OSS the main difference is the tunnel width.
    So, it seems that SBI rules that the new DW and x-cat type boats would be legal, which would seem to be the way to go to opening up the class for more competition???????
    My suggestion would be to invite any and all who wish to race. If there is truly an unfair advantage, there are ways of dealing with it.
