Thread: Crash Box?
Results 1 to 14 of 14
    Crash Box?
    Can someone tell me what a crash box is? How does it compare to a gearbox? Thanks for your help and sorry for the rookie question....
    A crash box doesn't shift while the engine is running. You put it in gear and go.
    So a crash box does not shift while a gear box does? What were race boats in the 80's running?
    Crash boxes have been around a long time. They are simple, light and dependable.
    it's a in-and-out tranmission. no gear reduction change.
    use the starter to bump the motor over and at the same time push the shifter in to foward, neutral or reverse. this obvious is done with the motors off. once in gear (forward,neutral, reverse) you start up the motor and go. to switch direction, you have to turn off the motor and switch
    Where the summer never ends
    If u need some ?! PM me !!!!
    Founding Member Buoy's Avatar
    Apache Jct. AZ
    Some would almost say I had one in my old boat with the B&W trans after I fused the clutch plates and still ran it until the end of the season, twice.
    It was fun around the docks.
    I just beat the hell out of that boat...
    Crash boxes are gearboxes. Borg Warner/Huber/Bam transmissions are gearboxes.
    Crash boxes use a dog clutch or a spline engagement. It is possible to engage while the engine is running (not recommended)
    BW/H/B transmissions use a clutch pack to engage a planetary for Forward and Reverse.
    Most crashboxes (Daytona/Kiekaffer/SCS) are on center input output , no ratio in forward but ratio in reverse.
    Ours crashboxes run Gears to give a ratio, rotation change and also multiple ratios forward or reverse and sometimes offset. We use a clutch to make the crashbox into a transmission. pneumatic over hydraulic or just pneumatic.
    pat W
    Attached Thumbnails Attached Thumbnails PA290004.JPG   inline6.JPG   P8150003.JPG
    Apache Jct. AZ
    Quote Originally Posted by shifter View Post
    pat W
    Showoff!!
    Very nice stuff!!
    Damn I wish I could play with the big boys.
    Great stuff!!
    Registered bluellama's Avatar
    1000 Islands/Ottawa
    Quote Originally Posted by chewiekw View Post
    Can someone tell me what a cash bar is? How does it compare to a gearbox? Thanks for your help and sorry for the rookie question....
    They are pretty much the same thing ........
    Ducking and covering ....
    I'm not even going to think I know a tenth of what Shifter knows, but this might give you a bit more clarity.
    If you think in terms of an auto or truck anaolgy, the crash box is a manual transmission and the others are an automatic transmission. The manual has no clutch or synchronization. It operates on gears directly meshed together. The automatic has a clutch pack inside that relies on hydraulic pressure to force it closed to keep the engagement. The manual only stops working when the absolute maximum torque loads break the gears or cause fatigue to a point where they fail. On the other side, the automatic's engagement clutch will slip at some point. And each time it slips it creates friction that wears the clutch and raises the oil temp. The more it slips, the more it wears and the easier it is to slip. Pretty soon, your engagement is lost.
    hey shifter what boat is the quad engine you have in your picture?...... sorry for the hi-jack
    That boat is a twin vee not a cat. I wouldnt mind doing a quad engine boat again......almost did one this winter...
    I wasn't trying to show off...... errrr ok I was...
    Thanks for the compliments!
    pat W
    If you can do it, it's not showing off.
