Results 1 to 9 of 9
    Anyone with turndown exhaust tips and hydraulic steering?
    Registered htrdlncn's Avatar
    Jan 2010
    Lake Travis
    Just put on donkey dongs (turn downs) and the exhaust will exit right over the steering rams and dont know if thats gonna work or not.
    Where the summer never ends
    Quote Originally Posted by htrdlncn View Post
    A friend of mine has this set up.......
    Attached Thumbnails Attached Thumbnails Garry's CIG with #5's on transom.jpg   cig g 3.jpg
    Jan 2010
    Lake Travis
    They way the tips are currently setup they dump over the rams,
    what I am wondering is if this is bad for tghe ram.
    Guess I should take some pics so you can see what I mean.
    Jan 2010
    Lake Travis
    Sorry took me so long..
    Here is what I am talking about, my friend Doug did flip the cylinder so the hoses are on the bottom which is better but I am still worried about the cylinder heating up.
    Obviously I wont be running engine with drive that far up so there will be more room between cylinder ram and exhaust dump with drive in a normal trim setting.
    All over da place.
    Can you just turn them outward about 15-20 degrees and not have to worry about anything?
    wwwActiveThunderBoats.com
    Jan 2010
    Lake Travis
    it would have to be at least 30-40deg to clear cylinder at which point
    there would be no benefit to running turndowns.
    I can also trim them shorter but again that would make it much louder.
    Unfortunately at this point I am very short on money so spending 300-600
    on mufflers is not an option. My slip/exhaust direction faces the marina owners house and I dont want to piss him off when I get home from bar hopping at 1-2am.
    I guess my question is would the exhaust be hot enough to heat cylinder to any extent,
    the steering is made by Marine machine.
    Exhaust is dry until right before inside of transom then it all mixes together before coming out the tip
    so by time it comes out of turndowns water and exhaust have mixed for approx 6"..
    You don't need those things. Take em off so that beast can be heard coming down the lake.
    I realy would not worry about the cylinder !!!!!!, just run it ...its not that hot !
    Only thing the cylinder will be black all the time....
