good read
Results 41 to 56 of 56
- 37,361
04-11-2013 04:14 AMYep,
- 37,361
04-12-2013 04:14 AMSome of the problems guys have had while towing are pretty interesting.....
04-12-2013 04:31 PM
Like using a hummer or F150???
04-14-2013 12:18 AM
Your truck will tow your boat fine. I use a SRW Cummins to tow my 50ft 3/4 car hauler weighing 25-30k daily. I do have some upgrades to the truck and trailer. Yes I have used a DRW but prefer and upgraded "super single" style SRW.
Make sure the truck and trailer are in very good condition. Worn parts make for slop
Air the tires up to Max Cold PSI
If your truck needs more stability air bags in the rear help
Would not hurt to upgrade the trucks hitch, drawbar, and ball to 20k
Would not hurt to upgrade the trailers tires to 14ply G load range. I run them even though trailer came with 10 ply E load range, never had a flat since upgrading in over 500,000 miles
Hand pack Trailer bearings every year. I have had bad luck with using the grease zerks to grease trailer bearings. Just blows the seals out.
EOH brakes on the trailer
Safety chain along with the winch strap on the boat and rear straps never hurt either
9'6" Wide is not legal to tow without a permit, but just avoid attention (i know thats hard with a badazz BT!) and play dumb. Since your recreational you do NOT need to pull into weigh stations. Recreational laws are different then commercial, and every state varies. There are ways to tow legal, and if interested, I would recommend researching them yourself. You can not trust what we post about actual laws (no offense) and if you ever are ticketed or pulled over, at least you will have the actual paperwork already printed out proving you are legal. Calling the DOT does not work either, they are lazy doughnut eaters that have not studied the law properly. So find the actual laws on paper, and try to decifer them since they are written in "lawyer speak".
2 spare tires and wheels
Spare bearings hubs etc
Tools to change
Feel your bearings and tires at every stop to see if they are hot, if they are you are already about to detroy a spindle, tire is low on air
Having a truck act as a bandaid for a improperly set up trailer is not magically "safe" like some on OSO feel. The Trailer handles the weight of the boat, the stability, the sway, the braking, etc etc. IMO the trailer is MORE important then the truck.
Enjoy!
- 37,361
04-14-2013 04:18 PMSome really good advice there.....
ThanksGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
04-16-2013 10:16 PM
Agreed, good info.
I use a F650, Cat, Allison with air ride. I've towed mine to Key West from STL, no permits. I did have a flat tire in ATL.
But i have a cordless 1/2 impact, which worked awesome. I felt like i was on a Nascar pit crew. Lol.
All except my gf was out taking pics of me.......which was causing a traffic jam. Clearly im a show stopper.........
Lmao.
- 37,361
- 37,361
04-18-2013 05:26 PMUnless his pants had fallen down, and his plumbers butt was hanging out, no show stopper there......
04-21-2013 09:04 PM
No bikini.......no crack showing.....at least i think.
04-22-2013 11:18 AM
drw truck is always better, especially if new to pulling 75' long 24,000 total weight.
with single rear wheel truck you can get a side to side sway at times which can be a challenge to handle
I would stay in the 60s on speed, it's not hard to run fast, it's being able to stay in control when somebody in front of you stops or slams on there brakes
my 2 cents
