Results 1 to 20 of 24
    454 Magnum Upgrades
    St. Louis; LOTO
    I have an stock Merc 454 magnum EFI 385 HP in my 1995 Cig 20.
    It is time to upgrade the motor/headers. Whats out there? Any recommendations? Whipple it?
    Sterling 1500!!!
    St. Louis; LOTO
    I want to upgrade the motor not replace it...
    Jc Performance got 515hp out of mine with the stock heads & intake. He just used a 525 cam, ported the heads & a good program of the efi.
    Registered Trim'd Up's Avatar
    STL, on the ILL side
    Quote Originally Posted by Tommy Gun View Post
    That's a shame. I have a 711 hp 548 that sure would make it fly.
    How much power are you looking to get?
    do the heads and cam bigger prop
    St. Louis; LOTO
    Much as I reasonably can out of this rebuild.
    Has Bravo 3.
    Charter Member mikes280's Avatar
    Charlotte.NC.
    bore it 60 put a 4.25 crank in it touch up the heads add a crane 741 and you have a 496 that can make up to 600hp
    How fast is that boat with the stock motor now?
    St. Louis; LOTO
    Quote Originally Posted by JupiterSunsation View Post
    68
    Are you sticking with the Bravo III after the rebuild or going to a Bravo I? That decision should influence how far you want to go HP-wise with this upgrade.
    Put a Black Hawk on it and gain mph for cheap
    St. Louis; LOTO
    Going to try it with a Bravo 1 lower...we'll see.
    St. Louis; LOTO
    Quote Originally Posted by Airpacker View Post
    Blackhawks have their own set of issues (shifting), but I have considered an Arneson as it would appear that it would produce he desired result and decent dockside manners.
    What shifting issues? never had a single shifting issue in 5 summers of running one behind an efi motor.
    Tommy Gun , I have a M1 procharger for your motor, keep everything alone and enjoy great cruise speeds without going into boost.
    Tommy, I'm really happy with what I did to my 454's. If you want the cam specs & stuff like that, PM me.
    St. Louis; LOTO
    I have been told they have problems with higher HP and have to be shifted like a crash box????.
    I think the first question a builder would ask is if you want to keep the EFI system.
    Registered Slandrew's Avatar
    long Island,N.Y.
    Quote Originally Posted by Bill N View Post
